Rabbitslayer Posted April 6, 2022 Report Share Posted April 6, 2022 I changed my battery today on my 2017 SEL. In doing so everything started up just fine except all of the buttons on the center console. No temperature controls, no radio buttons, no lights for airbags. The hazard button still works. The volume controls from the steering wheel still work. The radio still functions and the Radio display still works. What could I possibly have done to stop all of these buttons from working? I have tried pulling fuses (as per searching on this website has suggested) to no avail. Quote Link to comment Share on other sites More sharing options...
Will2U Posted April 6, 2022 Report Share Posted April 6, 2022 Did you reset your BMS after changing the battery? Most likely, that is the culprit. Quote Link to comment Share on other sites More sharing options...
Haz Posted April 6, 2022 Report Share Posted April 6, 2022 (edited) Below is a PDF download link to a section of the 2017 Edge Workshop Manual describing Battery Monitoring System operation, which includes this passage... Battery Replacement If the vehicle battery is replaced, it is very important to perform the BMS Reset using a diagnostic scan tool. If the battery monitoring system reset is not carried out, it holds the old battery parameters and time in service counter in memory. Additionally it tells the system the battery is in an aged state and may limit the Electrical Energy Management system functions. If you don't have a diagnostic scan tool, you may be able to find a national auto parts store willing to scan your Edge's programmable modules for any existing Digital Trouble Codes, which could reveal other contributing factors. Good luck! Charging System - 2.0L EcoBoost - Sys Op and Component Description - 2017 Edge Workshop Manual.pdf Multifunction Electronic Modules Diagnostic and Testing - 2017 Edge Workshop Manual.pdf Edited April 6, 2022 by Haz 1 Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted April 6, 2022 Report Share Posted April 6, 2022 (edited) You can reset your BMS with FORScan and the appropriate OBDII adapter. Lots of members including myself use this one here: MX OBDII Bluetooth Scanner Edited April 6, 2022 by onyxbfly Quote Link to comment Share on other sites More sharing options...
Rabbitslayer Posted April 6, 2022 Author Report Share Posted April 6, 2022 Well I took it to the store and did the reset but, code more error codes like the attached screenshot Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted April 7, 2022 Report Share Posted April 7, 2022 11 hours ago, Rabbitslayer said: Well I took it to the store and did the reset but, code more error codes like the attached screenshot The error code that you have their in your pic speaks to the exact problem that your facing! THE FCIM is the interface with the buttons that do not work for you. Have you tried disconnecting the negative cable for 10-20 min to see if that will reset the modules? Some have even left it disconnected over night! If you search the forums you will see that some people have had success disconnecting the negative cable. Good Luck! Quote Link to comment Share on other sites More sharing options...
Rabbitslayer Posted April 8, 2022 Author Report Share Posted April 8, 2022 I tried the remove the negative terminal for the entire night and I get the exact same response. I am getting a reader to find out all of the error codes from various modules. Is it to a point where it just might be easier to take it in? Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted April 8, 2022 Report Share Posted April 8, 2022 (edited) That's bizarre! Sorry to hear that you're still dealing with this! Usually removing the negative cable does the trick! Personally, I would get the code reader because, I like to have an idea of what of I'm potentially dealing with when going to any mechanic. There are lots of knowledgeable folks on this forum. Perhaps they can shed some light! @WWWPerfA_ZN0W @1004ron @enigma-2 @jmr061 @omar302 @macbwt Edited April 9, 2022 by onyxbfly 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted April 8, 2022 Report Share Posted April 8, 2022 (edited) Rabbitslayer reading the codes is the best first step in diagnostics, but learn from my lesson when buying an OBD2 device. I suspected that I had a stored evap code, but it didn't show up with the cheap OBD2 device I had, then I bought the OBDLink MX+ and it downloads Ford specific data, and it found that I did have a pending evap code. https://www.amazon.com/gp/product/B07JFRFJG6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Quote Recommended adapter for FORScan, Torque, BimmerCode, Dashcommand, AlfaOBD, Carista and many more Enhanced OEM support for Ford, GM, Mazda, Nissan/Infinity, Toyota/Lexus/Scion, Honda, Hyundai, Kia More Data OBDLink MX+ supports GM-LAN and Ford-MSC proprietary vehicle networks that provide access to thousands of additional parameters that are off-limits to all other wireless OBD scanners, including BlueDriver and FIXD. You could also get it read free of charge at a place like Autozone, although I have read reports that their readers don't always find existing codes. I see a few folks recommended that you reset the BMS, but you never responded to them. Edited April 8, 2022 by 1004ron 1 Quote Link to comment Share on other sites More sharing options...
Rabbitslayer Posted April 8, 2022 Author Report Share Posted April 8, 2022 (edited) I did do the BMS reset (flash headlights 5x, then pump brake 3x and battery would flash). That didn't do anything either. I found that I did have to do this procedure again when I reattached the negative terminal this morning. I am going to borrow another (a generic one I tried today didn't work) from a friend next week. I think this one will work with Forscan? https://www.amazon.com/dp/B005NLQAHS/ Edited April 8, 2022 by Rabbitslayer Quote Link to comment Share on other sites More sharing options...
1004ron Posted April 9, 2022 Report Share Posted April 9, 2022 The cheap generic devices may work with Forscan, but they typically don't read all Ford codes, as was my experience mentioned above. I've read mixed reports on resetting the BMS using headlight and brakes - Forscan is all I consider for that. Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted April 9, 2022 Report Share Posted April 9, 2022 I understand the hesitancy in regards to not wanting to spend monies for something that may or may not used more than once. I also understand that we have to work with the budget that we have available to us. Point your browser in this direction.... OBDLink-EX-FORScan Adapter This adapter was exclusively designed by the FORScan team. The main difference between the adapter and the one that 1004Ron mentioned is that this adapter is limited to FORScan use only. Although it is fully compatible and compliant with all OBDII specifications and fully bilateral. You may or may not have to pay for 3rd party apps to diagnose other vehicles. Unfortunately you do not get access to the full diagnostic suite that comes with the OBDLink MX. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 10, 2022 Report Share Posted April 10, 2022 Two possible causes come to mind, 1. when replacing the battery you moved a harness and either shorted to conndctor opened one or more pins, breaking the connection to the front controls interface module. Try retracing your steps and wiggle the harnesses you may have moved during the battery change. Or 2, you sparked the battery when reconnecting and sent a voltage spike into the system. I know that CAN networks are supposed to be resistant to spikes, but these are still voltage senstitive components. If you take to the dealer for troubleshooting, believe it has a one hour labor cost. Don't know what the cost to replace is, but you could ask for a rebuilt or remanufactured unit to keep the costs down. (Do you have an extended warranty on the car)? 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted April 10, 2022 Report Share Posted April 10, 2022 (edited) The above photo of the Innova 5410 scan tool shows a U0256 DTC, associated with the Powertrain Control Module's continuous memory, as being the third of three DTCs discovered by the scan tool, though it's unclear if all three DTCs involve the PCM. If the other two Digital Trouble Codes are known, please post them, and we'll work our way through, but for now, let's examine the U0256 PCM DTC. The following is the diagnostic routine prescribed in the 2017 Edge Workshop Manual for determining U0256 DTC cause(s) and corrective action(s), Pinpoint Test K. The total file size of my document attachments are limited here, so I'll post any specific Workshop Manual sections the Pinpoint Test references after your results show a need for the additional information. If you are comfortable providing me your Edge's VIN, feel free to use the Forum's private Message feature, and then any subsequent Guided Diagnostic Routines can be specific for your vehicle, based upon its Build information. Good luck! DTC Fault Trigger Condition-PCM DTC Description Fault Trigger Conditions U0256 Lost Communication With Front Controls Interface Module "A" The PCM sets this DTC if data messages from the Front Control Interface Module (FCIM) through the Gateway Module (GWM) are missing. Normal Operation and Fault Conditions REFER to: Communications Network - System Operation and Component Description (418-00 Module Communications Network, Description and Operation). Possible Sources Communications network concern FCIM BCM (Body Control Module) GWM PCM PINPOINT TEST K: U0256 K1 VERIFY THE CUSTOMER CONCERN Ignition ON. Verify there is an observable symptom present. Is an observable symptom present? Yes GO to K2 The inoperative center stack controls are your observable symptom. No The system is operating normally at this time. The DTC may have been set due to high network traffic or an intermittent fault condition. K2 CHECK THE COMMUNICATION NETWORK Using a diagnostic scan tool, perform a network test. Did the FCIM pass the network test? Yes GO to K3 No REFER to: Communications Network (418-00 Module Communications Network, Diagnosis and Testing). K3 PERFORM FCIM (FRONT CONTROLS INTERFACE MODULE) SELF-TEST Using a diagnostic scan tool, perform a FCIM self-test. Are any Diagnostic Trouble Codes (DTCs) recorded? Yes REFER to: Information and Entertainment System (415-00A Information and Entertainment System - General Information - Vehicles With: AM/FM/CD/SYNC, Diagnosis and Testing). OR REFER to: Information and Entertainment System (415-00B Information and Entertainment System - General Information - Vehicles With: Touchscreen Display, Diagnosis and Testing). OR REFER to: Information and Entertainment System (415-00C Information and Entertainment System - General Information - Vehicles With: Sony Audio System, Diagnosis and Testing). No GO to K4 K4 CHECK THE BCM (BODY CONTROL MODULE) DIAGNOSTIC TROUBLE CODES (DTCS) Using a diagnostic scan tool, retrieve the BCM Diagnostic Trouble Codes (DTCs). Are any Diagnostic Trouble Codes (DTCs) recorded? Yes REFER to: Body Control Module (BCM) (419-10 Multifunction Electronic Modules, Diagnosis and Testing). No GO to K5 K5 PERFORM THE PCM (POWERTRAIN CONTROL MODULE) SELF-TEST Using a diagnostic scan tool, perform the PCM self-test. Is DTC P0562 or DTC P0563 recorded? Yes REFER to PCM DTC Chart in this section. No GO to K6 K6 RECHECK THE PCM (POWERTRAIN CONTROL MODULE) DIAGNOSTIC TROUBLE CODES (DTCS) NOTE: If new modules were installed prior to the DTC being set, the module configuration may be incorrectly set during the PMI, or the PMI may not have been carried out. Using a diagnostic scan tool, clear the Diagnostic Trouble Codes (DTCs). Wait 10 seconds. Repeat the PCM self-test. Is DTC U0256 still present? Yes GO to K7 No The system is operating correctly at this time. The DTC may have been set due to high network traffic or an intermittent fault condition. K7 CHECK FOR DTC (DIAGNOSTIC TROUBLE CODE) U0256 SET IN OTHER MODULES Using a diagnostic scan tool, clear all Diagnostic Trouble Codes (DTCs). Ignition OFF. Ignition ON. Wait 10 seconds. Using a diagnostic scan tool, retrieve all Continuous Memory Diagnostic Trouble Codes (CMDTCs) from all modules. Is DTC U0256:87 set in any other module? Yes GO to K8 No GO to K9 K8 CHECK FOR CORRECT FCIM (FRONT CONTROLS INTERFACE MODULE) OPERATION Ignition OFF. Disconnect and inspect all FCIM connectors. Repair: corrosion (install new connector or terminals – clean module pins) damaged or bent pins – install new terminals/pins pushed-out pins – install new pins as necessary Reconnect all the FCIM connectors. Make sure they seat and latch correctly. Operate the system and determine if the concern is still present. Is the concern still present? Yes CHECK OASIS for any applicable Technical Service Bulletins (TSBs). If a TSB exists for this concern, DISCONTINUE this test and FOLLOW TSB instructions. If no Technical Service Bulletins (TSBs) address this concern, VIN required to access Guided Routine (FCIM) No The system is operating correctly at this time. The concern may have been caused by module connections. ADDRESS the root cause of any connector or pin issues. K9 CHECK FOR CORRECT PCM (POWERTRAIN CONTROL MODULE) OPERATION Ignition OFF. Disconnect and inspect PCM connector. Repair: corrosion (install new connector or terminals – clean module pins) damaged or bent pins – install new terminals/pins pushed-out pins – install new pins as necessary Reconnect the PCM connector. Make sure it seats and latches correctly. Operate the system and determine if the concern is still present. Is the concern still present? Yes CHECK OASIS for any applicable Technical Service Bulletins (TSBs). If a TSB exists for this concern, DISCONTINUE this test and FOLLOW TSB instructions. If no Technical Service Bulletins (TSBs) address this concern, VIN required to access Guided Routine (PCM) No The system is operating correctly at this time. The concern may have been caused by module connections. ADDRESS the root cause of any connector or pin issues. Edited April 22, 2022 by Haz 5 Quote Link to comment Share on other sites More sharing options...
Rabbitslayer Posted April 15, 2022 Author Report Share Posted April 15, 2022 I was able to connect up a BT device from a friend tonight and it was able to get more information. Here is what I have found. I did do the Battery Monitoring System Reset successfully (FORScan reported success). I have omitted the VIN below... Thinking back to when I replaced the battery there was only once cable that was "jiggled" and I have checked that connection and don't see any issue. No other cables were in the way. Hope this is enough information! Interface: Adapter: ELM327 v1.5 Min.delay: 18 ms ( Good) Errors: None Vehicle: Model: Ford Edge Engine: EcoBoost Gasoline Turbocharged Direct Injection Capacity: 2.0L Year: 2017 Generation: 2017 MY Fuel: Gasoline Transmission gear: Automatic PCM - Powertrain Control Module Part number: G2GA-12A650-BSA Calibration level: H2GA-12A650-BTA (latest known: H2GA-12A650-BTD) Strategy : H2GA-14C204-BTA Hardware type: FB5A-12B684-CA Total Distance: 49370.0 km OBDII - On Board Diagnostic II APIM - Accessory Protocol Interface Module Part number: FR3T-14D212-RB Calibration level: FR3T-14D212-RB (latest known: HM5T-14D212-AA) Strategy : E1BT-14D205-AJ PAM - Parking Aid Module Part number: FU5T-15K866-BK Calibration level: FU5T-15K866-BK (latest known: FU5T-15K866-BL) Strategy : FU5T-14C090-BK BdyCM - Body Control Module Part number: HU5T-14B476-BAK Calibration level: HU5T-14B476-BAK (latest known: HU5T-14B476-SAA) Strategy : HU5T-14C184-AAK BECMB - Battery Energy Control Module B Part number: HU5T-14G490-AF Calibration level: HU5T-14G490-AF Strategy : HU5T-14G499-AE Code: P193E - A/C Clutch Request Signal Code: U0164 - Lost Communication With HVAC Control Module Code: U0256 - Lost Communication With Front Controls Interface Module A Code: U3006 - Control Module Input Power A Circuit / Open Code: U3007 - Control Module Input Power B Circuit / Open Code: U3013 - Control Module Input Power C Circuit / Open Code: U3014 - Control Module Input Power D Circuit / Open Additional Fault Symptom: - Circuit Voltage Below Threshold Code: B1448 - Right Rear Stop/Position Lamp Output Additional Fault Symptom: - Circuit Short To Battery Or Open Code: U0256 - Lost Communication With Front Controls Interface Module A Additional Fault Symptom: - Missing Message Code: B1438 - Battery Current Sensor Additional Fault Symptom: - Frequency Modulated / Pulse Width Modulated Failures Quote Link to comment Share on other sites More sharing options...
Rabbitslayer Posted April 15, 2022 Author Report Share Posted April 15, 2022 Picture of the wire I mentioned jiggling. It is to the right of the battery and attached to a harness it didn't come loose from. Quote Link to comment Share on other sites More sharing options...
Rabbitslayer Posted April 20, 2022 Author Report Share Posted April 20, 2022 It is a stumper eh? Quote Link to comment Share on other sites More sharing options...
JoeVic Posted April 21, 2022 Report Share Posted April 21, 2022 Rabbitslayer, when you read all of those codes mentioned, were you able to clear them? After my battery died and the dealer checked it out and said everything appeared to be okay, I ran FORscan Lite and had almost two handfuls of codes related to "..Lost communication with ..." I was able to clear all of them, they didn't return and everything appeared to be good. A year later I go to the dealer to have my trans updated to the latest TSB and then I notice my interior lighting wasn't working correctly. I ran another full scan and this time I only saw a few "...Lost communication with ....module" codes. Again I clear everything and the interior lighting returns to normal. It appears the interfaces between all of these modules and systems are rather wonky. If you can, try resetting any errors that you see (after documenting them) and see what happens. 1 Quote Link to comment Share on other sites More sharing options...
Rabbitslayer Posted April 22, 2022 Author Report Share Posted April 22, 2022 Will resetting the codes enable the buttons? Quote Link to comment Share on other sites More sharing options...
Haz Posted April 22, 2022 Report Share Posted April 22, 2022 (edited) The action of clearing DTCs, and running self-test routines on involved modules afterward, is repeatedly mentioned in the Pinpoint K diagnostic in my prior post, above. It is entirely possible that your Edge's failing/failed battery condition is the root cause of the many DTCs that Forscan revealed. Clearing the DTCs very well may restore the operation of your center-stack controls. Please let us know how it turns out. Good luck! Edited April 22, 2022 by Haz 1 Quote Link to comment Share on other sites More sharing options...
Rabbitslayer Posted April 22, 2022 Author Report Share Posted April 22, 2022 I can get to Point K4. I try to reset the BdyCM DTC and I am still getting the U0256 for that module. What should I do from section 419-10? Quote Link to comment Share on other sites More sharing options...
Haz Posted April 22, 2022 Report Share Posted April 22, 2022 (edited) Body Control Module DTC U0256 Pinpoint P diagnostic routine from 2017 Edge Workshop Manual... Good luck! U0256:87 DTC Fault Trigger Conditions DTC Description Fault Trigger Conditions U0256:87 Lost Communication With Front Controls Interface Module "A" : Missing Message A continuous memory DTC that sets in the BCM if messages from the FCIM through the GWM are missing. Possible Sources Communication network concern Battery voltage concern GWM concern FCIM BCM PINPOINT TEST P: U0256:87 P1 VERIFY THE CUSTOMER CONCERN Ignition ON. Verify there is an observable symptom present. Center Stack Controls Continue To Be Inoperative ? Is an observable symptom present? Yes GO to P2 No The system is operating normally at this time. The DTC may have been set due to high network traffic or an intermittent fault condition. CLEAR the DTC. P2 CHECK THE COMMUNICATION NETWORK Using a diagnostic scan tool, perform a network test. Does the FCIM pass the network test? Yes GO to P3 No DIAGNOSE no communication with the FCIM. REFER to: Communications Network (418-00 Module Communications Network, Diagnosis and Testing). P3 CHECK THE BCM (BODY CONTROL MODULE) CONTINUOUS MEMORY DIAGNOSTIC TROUBLE CODES (CMDTCS) Using a diagnostic scan tool, clear the Diagnostic Trouble Codes (DTCs). Wait 10 seconds. Using a diagnostic scan tool, check the BCM Continuous Memory Diagnostic Trouble Codes (CMDTCs). Is DTC B11D9:16, B11D9:17, U3006:16, U3006:17, U3007:16, U3007:17, U3013:16, U3013:17, U3014:16 or U3014:17 recorded? Yes For DTC B11D9:16, U3006:16, U3007:16, U3013:16 or U3014:16, GO to Pinpoint Test J For DTC B11D9:17, U3006:17, U3007:17, U3013:17 or U3014:17, GO to Pinpoint Test K No GO to P4 P4 RETRIEVE THE DIAGNOSTIC TROUBLE CODES (DTCS) FROM THE FCIM (FRONT CONTROLS INTERFACE MODULE) SELF-TEST Using a diagnostic scan tool, perform the FCIM self-test. Are any Diagnostic Trouble Codes (DTCs) recorded? Yes REFER to: Information and Entertainment System (415-00A Information and Entertainment System - General Information - Vehicles With: AM/FM/CD/SYNC, Diagnosis and Testing). REFER to: Information and Entertainment System (415-00B Information and Entertainment System - General Information - Vehicles With: Touchscreen Display, Diagnosis and Testing). REFER to: Information and Entertainment System (415-00C Information and Entertainment System - General Information - Vehicles With: Sony Audio System, Diagnosis and Testing). No GO to P5 P5 RECHECK THE BCM (BODY CONTROL MODULE) CONTINUOUS MEMORY DIAGNOSTIC TROUBLE CODES (CMDTCS) Using a diagnostic scan tool, clear the Diagnostic Trouble Codes (DTCs). Wait 10 seconds. Using a diagnostic scan tool, check the BCM Continuous Memory Diagnostic Trouble Codes (CMDTCs). Is DTC U0256:87 still present? Yes GO to P6 No The system is operating correctly at this time. The DTC may have been set due to high network traffic or an intermittent fault condition. P6 CHECK FOR DTC (DIAGNOSTIC TROUBLE CODE) U0256 SET IN OTHER MODULES Using a diagnostic scan tool, clear the Diagnostic Trouble Codes (DTCs). Ignition OFF. Ignition ON. Wait 10 seconds. Using a diagnostic scan tool, retrieve all Continuous Memory Diagnostic Trouble Codes (CMDTCs). Is DTC U0256 set in any other module? Yes GO to P7 No GO to P8 P7 CHECK FOR CORRECT FCIM (FRONT CONTROLS INTERFACE MODULE) OPERATION Disconnect and inspect the FCIM connector. Repair: corrosion (install new connector or terminals - clean module pins) damaged or bent pins - install new terminals/pins pushed-out pins - install new pins as necessary Reconnect the FCIM connector. Make sure it seats and latches correctly. Operate the system and determine if the concern is still present. Is the concern still present? Yes CHECK OASIS for any applicable service articles: TSB, GSB, SSM or FSA. If a service article exists for this concern, DISCONTINUE this test and FOLLOW the service article instructions. If no service articles address this concern, VIN required to access Guided Routine (FCIM) No The system is operating correctly at this time. The concern may have been caused by module connections. ADDRESS the root cause of any connector or pin issues. P8 CHECK FOR CORRECT BCM (BODY CONTROL MODULE) OPERATION Disconnect and inspect all BCM connectors. Repair: corrosion (install new connector or terminals - clean module pins) damaged or bent pins - install new terminals/pins pushed-out pins - install new pins as necessary Reconnect the BCM connectors. Make sure they seat and latch correctly. Operate the system and determine if the concern is still present. Is the concern still present? Yes CHECK OASIS for any applicable service articles: TSB, GSB, SSM or FSA. If a service article exists for this concern, DISCONTINUE this test and FOLLOW the service article instructions. If no service articles address this concern, VIN required to access Guided Routine (BCM) No The system is operating correctly at this time. The concern may have been caused by module connections. ADDRESS the root cause of any connector or pin issues. Edited April 22, 2022 by Haz 1 1 Quote Link to comment Share on other sites More sharing options...
Rabbitslayer Posted April 29, 2022 Author Report Share Posted April 29, 2022 I did trying to reset as many modules as I could with no real luck. However, last night the entire front panel started working again. I am not sure why it is working now (and hope it continues working) but, maybe it was a connection issue? 3 Quote Link to comment Share on other sites More sharing options...
