2017 Sport - Shark Fin Antenna
bscott94
I was washing my car a few weeks ago and noticed the cover on the antenna is loose at the front of the fin. I've searched on here and only found antennas broken off completely. Does the cover pop on and off? Can I take it off and stick it back on with double sided tape or do I need to replace the whole unit for the cover to be mounted securely?
Edited by bscott94
2 hours ago, omar302 said:
Attached is the service procedure for removal of the antenna.
Satellite Radio Antenna.pdf
Thanks. Is there anything that says whether or not the plastic fin shaped cover can be removed from the base? I know there are things between the fin and the base so there has to be a way to get in there. I don't know if they're screwed/clipped together or if they're glued together after the internals are installed.
  • 2 years later...
Posted (edited)
Well it finally happened. I got home Friday and the cover was missing. I think it was blown off in the touchless carwash. It only took like 15 trips through it. I ordered a used one on Ebay but it's white so I'm going to try to wrap it in in black carbon fiber vinyl. We'll see how that looks.
@omar302, do you have the file for this in the instructions?
1. Lower the headliner. Refer to: Headliner ­ Lowering (501­05 Interior Trim and Ornamentation, Removal and Installation).
Edited by bscott94
