A/C still not working after recharge
Or you overcharged the system and when its hot outside or driving around the engine compartment heats up causing the High Pressure switch to trip.  When the system stops working see if the AC clutch is engaged if its not the AC High Pressure switch tripped, if the AC works after the car has cooled down or the outside temperature is lower it is definitely over charged.  If this is the case get a cheap gauge; on on a refill can will work; with the car running AC on MAX; car doors open bleed low pressure side to between 30 - 35 PSI
Did you find and fix the initial leak? Putting in a can may have only put a band-aid on the problem. Whatever caused to original leak is still leaking.
There are several areas where the system can leak. Putting in dye helds locate the area, as well as using a leak detector (above post).
But my guess is the can of refrigerant reestablished the pressures and it subsequently leaked out after it sit for awhile. You can’t properly recharge the system by dumping in a can of refrigerant.
The existing refrigerant needs to be pumped out and weighed. Then pumped down under a vacuum and held to prove the system is leak tight. Then the proper anount of refrigerant pumped in. (Label on the underside of the hood tells how much). But first, you can't expect the hold a charge  until you find the leak(s).
Take it in to a professional and get it fixed properly.
