Service Advancetrac light on 2012 Edge while in idle
2012 Edge
I just bought a 2012 edge w only 34k miles in great shape.  I keep getting service advancetrac when idling in park.  Never while driving.   This cat is really awesome but I wish I could solve this issue.  The dealer changed the steering tilt sensor but it didn’t fix it.
  As it only happens at idle, I'd suspect your battery is getting weak or the charging system is not covering the battery losses.
  First thing I'd check for are corroded or loose battery terminals.
  Then run a CCA test on the battery and an voltage output test on tbe alternator at idle.
Edited by enigma-2
extended idling with climate control on is known to prompt this ghost error.  programming update fixes it, but leaving it alone won't hurt anything, per TSB
https://drive.google.com/drive/u/4/folders/1VZ5-ZQ3yDQtlxIF8MGDwtT-2CVpaCZkn
  • 4 months later...
