2007 ford edge noise in front end
Asovietsloth
if the noise exists when turning the wheel at idle while parked, then most likely it is the strut mount. strut mounts should generally be replaced with struts - motorcraft/ford brand is by far the best choice from user reports.
definitely look at the links and the rest of the suspension bushings as suggested above. control arms, tie rod ends, are all possible suspects if mounts are ruled out.
