tmise40 Posted March 26, 2022 Report Share Posted March 26, 2022 (edited) Sounds pricey! Are you guys actually changing the tranny fluid three times? Seems like a lot of $$ waste! Just cost me $45 for 5 quarts of Mercon V and I believe this thing takes 11 qts or so! Also heard it should be changed every 30,000 miles since the filter can’t be changed unless you take the tranny apart?! Crazy! Also the ptu oil change looks like a pain also. You guys have any helpful advice on that? Heard it should be changed again after 1,000 miles in order to get most the black oil out. My Edge is a 2009 with 152,000 miles, bought it at 120,000 miles so I’m not sure if any of these fluids have ever been changed. Edited March 26, 2022 by tmise40 Quote Link to comment Share on other sites More sharing options...
1004ron Posted March 26, 2022 Report Share Posted March 26, 2022 1 hour ago, tmise40 said: Sounds pricey! Are you guys actually changing the tranny fluid three times? Seems like a lot of $$ waste! Just cost me $45 for 5 quarts of Mercon V and I believe this thing takes 11 qts or so! Also heard it should be changed every 30,000 miles since the filter can’t be changed unless you take the tranny apart?! Crazy! Also the ptu oil change looks like a pain also. You guys have any helpful advice on that? Heard it should be changed again after 1,000 miles in order to get most the black oil out. My Edge is a 2009 with 152,000 miles, bought it at 120,000 miles so I’m not sure if any of these fluids have ever been changed. "Seems like a lot of waste" would be a personal opinion, but interested to hear how you came to that opinion. A quick forum search should answer your other questions. 1 Quote Link to comment Share on other sites More sharing options...
ZeroPlus Posted March 26, 2022 Report Share Posted March 26, 2022 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 2, 2022 Report Share Posted April 2, 2022 On 3/26/2022 at 7:09 AM, tmise40 said: My Edge is a 2009 with 152,000 miles, bought it at 120,000 miles so I’m not sure if any of these fluids have ever been changed. I have an 09 MKX. To be sure of everything, I'd change all fluids. All fluids age. Includes those areas that are "supposed" to be lifetime, like the PTU and RDU. At 150k, I'd also be looking at new plugs. (Not a big fan of 90k intervals). Have you changed the cabin air filter since you bought the car? How about the seat filters? Have you replaced the fuel tank and air bags? Quote Link to comment Share on other sites More sharing options...
