Eric46 Posted February 27, 2022 Report Share Posted February 27, 2022 Hi Everyone - I'm new to the forum and need some help. I've attempted a rear break job and DID NOT put the car into "Maintenance mode" before I removed the rear pads, rotors. Now I've got a problem b/c I can't get the pistons back in. I attempted to put the car into "MM" and the driver caliper popped.. and now needs to be replaced. I'm looking for parts but would love any input on completing this job. Thank you Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 2, 2022 Report Share Posted March 2, 2022 Have you tried compressing the pistons? A tool like this makes it easy. https://www.amazon.com/dp/B085THCFPJ/ref=cm_sw_r_apan_glt_i_BVWEBN5WX2MN0J2XT20R?_encoding=UTF8&psc=1 Quote Link to comment Share on other sites More sharing options...
handfiler Posted March 2, 2022 Report Share Posted March 2, 2022 23 minutes ago, enigma-2 said: Have you tried compressing the pistons? A tool like this makes it easy. https://www.amazon.com/dp/B085THCFPJ/ref=cm_sw_r_apan_glt_i_BVWEBN5WX2MN0J2XT20R?_encoding=UTF8&psc=1 That wont work for the rear caliper. You need the tool that rotates the piston as it compresses it. Disc Brake Caliper Compression Wind Back Tool 2 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 3, 2022 Report Share Posted March 3, 2022 Opps, sorry. Something like this then? (Autozone OEM 27111 loner tool program. Probably not too expensive to rent.) Quote Link to comment Share on other sites More sharing options...
jmr061 Posted March 3, 2022 Report Share Posted March 3, 2022 5 hours ago, handfiler said: That wont work for the rear caliper. You need the tool that rotates the piston as it compresses it. Disc Brake Caliper Compression Wind Back Tool The 15's and up don't use the screw type that I know of. When I did the brakes on my 16 the service manual didn't call for screw type. I believe that is 14 and earlier. Quote Link to comment Share on other sites More sharing options...
lildisco Posted March 3, 2022 Report Share Posted March 3, 2022 I know the non sports/ST's are screw in style. Quote Link to comment Share on other sites More sharing options...
jmr061 Posted March 3, 2022 Report Share Posted March 3, 2022 Here is what I have for the 2016... 2016 Edge Rear Brake Pads.pdf Quote Link to comment Share on other sites More sharing options...
handfiler Posted March 3, 2022 Report Share Posted March 3, 2022 31 minutes ago, jmr061 said: Here is what I have for the 2016... 2016 Edge Rear Brake Pads.pdf Refer to step 6 in the documentation you provided. 6. NOTICE: Use care when pushing the caliper piston into the caliper piston bores or damage to components may occur. Compress the brake caliper piston until the piston bottoms out in the brake caliper bore. • NOTICE: Do not apply over 20 Nm (177 in-lb) force when rotating the brake caliper piston or internal damage to the brake caliper may occur Quote Link to comment Share on other sites More sharing options...
jmr061 Posted March 3, 2022 Report Share Posted March 3, 2022 The tool isn't the spinning tool, you will also note they say if it doesn't bottom out then try to spin it while using the retractor. Quote Link to comment Share on other sites More sharing options...
handfiler Posted March 3, 2022 Report Share Posted March 3, 2022 37 minutes ago, jmr061 said: The tool isn't the spinning tool, you will also note they say if it doesn't bottom out then try to spin it while using the retractor. I stand corrected. My apologies for creating confusion. Quote Link to comment Share on other sites More sharing options...
Eric46 Posted March 4, 2022 Author Report Share Posted March 4, 2022 Hi all - thank you so much for the help and comments. However, I did not use the piston compression tool. I actually took the motor off of the caliper and manually (crescent wrench) spun the piston back. Once the brakes were removed I could not get the vehicle into MM. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 5, 2022 Report Share Posted March 5, 2022 may need to reinitialize it. lot of computerization these days. try removing the batt terminal for a few minutes and see if that does it. otherwise may need to use forscan for windows w extended license OR schedule a dealer visit to fix it. Quote Link to comment Share on other sites More sharing options...
