dug66 Posted February 23, 2022 Report Share Posted February 23, 2022 I want to install Daytime running lights on my 2013 SE Edge which does not have any at this time. I wondered if anyone knows does the existing lights wiring have the wiring for the daytime lights or will I have to add it? Quote Link to comment Share on other sites More sharing options...
kc300c Posted June 28, 2022 Report Share Posted June 28, 2022 (edited) Hi dug66, I need a little clarification. Are you wanting to add the OEM style accent lights or are you wanting to install true aftermarket Daytime Running Lights? Our EDGE-2V4 LED DRL kit comes everything you need to install and operate the LED DRLs. Here is a link to all of the options we offer in our Edge DRL kit product line: DriveBright Edge LED DRL kits - Product page Here is a customer's Edge SE before and after pictures: Some of our other customer photos: Edited June 28, 2022 by kc300c added photo Quote Link to comment Share on other sites More sharing options...
2nd Edge Posted August 22, 2022 Report Share Posted August 22, 2022 i used forscan to enable the factory DRL set up ,..which is the yellow turn signal lamps ON i wish i knew how to get the lower fascias vertical lights to do this instead Quote Link to comment Share on other sites More sharing options...
kc300c Posted August 31, 2022 Report Share Posted August 31, 2022 There is not a setting that you can adjust in Forscan that will allow the accent lights to automatically turn on as DRLs. Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted September 1, 2022 Report Share Posted September 1, 2022 We need you to make DRLs for the 2015-2018 edges! Quote Link to comment Share on other sites More sharing options...
omar302 Posted September 1, 2022 Report Share Posted September 1, 2022 1 hour ago, onyxbfly said: We need you to make DRLs for the 2015-2018 edges! ☝️☝️☝️ +1 1 Quote Link to comment Share on other sites More sharing options...
