Victor Posted February 20, 2022 Report Share Posted February 20, 2022 (edited) Quick question, which oil would you guys recommend for a 2009 Ford Edge Limited with 123,000+ miles? Lately, I have been using Mobile 1 High Mileage Full Synthetic. Any thoughts? Edited February 20, 2022 by 1004ron Quote Link to comment Share on other sites More sharing options...
1004ron Posted February 20, 2022 Report Share Posted February 20, 2022 Just stick with the oil you're using, or any other good name brand full synthetic of the correct grade specified in your owners manual. Not sure how long you've been around automotive forums, but "oil threads" are in abundance, and its typically the same as "how long is a piece of string?" 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 24, 2022 Report Share Posted February 24, 2022 the interval is more important than the brand. don't try to overextend intervals, either in terms of time or mileage. use a good filter. motorcraft certainly does a good job, but there are better filters, my preferred one being the Purolator Boss (if you can find it lol). your ride is nearly 15 years old. i don't know if it has had a water pump timing pump job done yet, but if not, do yourself a favor and step up to at least a 5W30 oil yearround. Shell Rotella Gas Truck has made the engine run the quietest in my testing, but quietness doesn't have a correlation to wear. 1 1 Quote Link to comment Share on other sites More sharing options...
Victor Posted February 25, 2022 Author Report Share Posted February 25, 2022 I change the oil and filter every 6 months or so. As for the filter, I use the Motorcraft FL-500 I haven't changed it since last year in July so it's about time I get to it. I don't know if the previous owner had the water pump worked on or not. 1 Quote Link to comment Share on other sites More sharing options...
DILLARD000 Posted February 25, 2022 Report Share Posted February 25, 2022 Yep, frequency of Oil+Filter changes is more important than brands. Do my vehicles every 6mths: 0w30.FullSyn in Spring, 0w20.FullSyn in Fall In a warmer climate, I'd use Ow30.FullSyn year round. Use K&N# HP series OilFilters; quality is good & they have an EasyOffHexNut built in. Quote Link to comment Share on other sites More sharing options...
Victor Posted February 25, 2022 Author Report Share Posted February 25, 2022 I live in LA, and since my Edge has over 120,000 miles on it, I've been using 10w30 Full Synthetic. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 25, 2022 Report Share Posted February 25, 2022 if i had to choose, i would say the filter is more important than the oil, given the relative parity among off the shelf oil brands these days. while there is a certification process for oil, there really isn't one for filters ... yet. as they say, with enough time, anything will be regulated lol. 6 months is a good interval for the MC filter, assuming not over 7500 miles - of NORMAL driving. if LA traffic is torture testing your Edge, move to a better filter, a 20K filter like the BOSS or the Fram ULTRA/Titanium can be changed on the second or even the third oil change (assuming avg mileage) and not break a sweat. 1 Quote Link to comment Share on other sites More sharing options...
Victor Posted March 6, 2022 Author Report Share Posted March 6, 2022 Thank you for all of your inputs guys. I appreciate it. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 10, 2022 Report Share Posted March 10, 2022 I have ford garage change oil (TheWorks for tire rotation and inspection). They use synthetic blend and Motorcraft filter. Think mine has around 127k miles. Diverting a bit, have you changed your coolant? Ford garage switched my 2009 MKX over to latest coolant. Said they couldn’t buy the gold anymore. Changing coolant important for pump longevity. Also consider changing tranny fluid, the PTU fluid and the power steering fluid, the rear axle and brake and blinker fluids. Concerning the use of high mileage oil, consider that Mobile 1 High Mileage will give you better fuel economy (which is always good) but not as much protection for your engine. 1 1 Quote Link to comment Share on other sites More sharing options...
Victor Posted March 13, 2022 Author Report Share Posted March 13, 2022 @enigma-2 I'm about to reach 124,000 miles. But as I previously stated, the last time I changed my oil was last year in July. So it's about time I change it again. Regarding the coolant, I've only changed it one time and that was in 2020 if im not mistaken. Bro, did you really say I should consider changing the blinker fluid? Lmfao I have H11 LED headlights so I don't need Blinker Fluid. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 13, 2022 Report Share Posted March 13, 2022 No need to change the blinker fluid then. Don't forget to switch your tires over from winter air to summer air next month. (Unless your running snow tires. No need for those as they will have melted by then). I have the Ford garage change mine as I'm allergic to lug nuts. Touch one and I brake (sic) out in torque. Yea, I know, all torque, no action. 1 Quote Link to comment Share on other sites More sharing options...
