RJG Posted February 14, 2022 Report Share Posted February 14, 2022 (edited) 2012 Limited Edge. My fault....tugged on it too hard. Broke off the tab that holds the plate in place. Where you put the filter in or take out. Taped it back tight. Question....was the tab connected to the plate, or to the body of the assembly. Can't tell from looking at broken tab. If plate, will buy another one. Otherwise tape is holding it tight. Thanks Edited February 14, 2022 by RJG Quote Link to comment Share on other sites More sharing options...
Haz Posted February 14, 2022 Report Share Posted February 14, 2022 (edited) Per the below images, the latching tab is on the left side of the cover-plate and its right side fixed-tab engages in the slot on the assembly housing's right side... Good luck! Edited February 14, 2022 by Haz 1 Quote Link to comment Share on other sites More sharing options...
RJG Posted February 15, 2022 Author Report Share Posted February 15, 2022 Thanks....Have had the cover plate in my hands several times, but couldn't tell if the tab broke off from it. So just have to stop by Ford dealership and order that plate. Thanks again. Quote Link to comment Share on other sites More sharing options...
