Oil leaking and smell
mhamad ismail
usually it is a power steering line at fault.
if you have AWD, it can leak between the transmission and PTU (front "differential"). most times it will leak PTU fluid (black and smelly) but sometimes it will leak trans fluid also.
suggest cleaning the area thoroughly with engine degreaser or brake parts cleaner (CFC free) then following it as it develops to pinpoint the culprit.
Suspect it's AutoTransFluid\ATF\MerconV (red\pink color)
leaking around right FrontAxle seal at PowerTransferUnit\PTU.
Believe it's a double Seal, for both ATF & PTU GearOil.  Check your ATF level, see if it's low.
Fix is to:
~ remove right FrontAxle,
~ remove old seal,
~ install new seal,
~ re-install right FrontAxle..
Link to vid on replacing this seal.
https://youtu.be/fLFFcVHptxs
Edited by DILLARD000
  • Like 3
