irvin Posted February 7, 2022 Report Share Posted February 7, 2022 what do you use for long life and best usage? motorcraft, ngk-platinum, iridium ? thanks for any info. Quote Link to comment Share on other sites More sharing options...
1004ron Posted February 7, 2022 Report Share Posted February 7, 2022 I use these: Ruthenium HX™ Spark Plugs - NGK Spark Plugs Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 7, 2022 Report Share Posted February 7, 2022 motorcraft is optimal for price vs performance, but you can certainly upgrade to reliable name brands with more advanced tech. lifespan is yet to be proven in comparison, but 2011 on with the Ti-VCT, plug life has not been as much of an issue. 2 Quote Link to comment Share on other sites More sharing options...
irvin Posted February 8, 2022 Author Report Share Posted February 8, 2022 20 hours ago, 1004ron said: I use these: Ruthenium HX™ Spark Plugs - NGK Spark Plugs LTR6AHX ? Quote Link to comment Share on other sites More sharing options...
1004ron Posted February 8, 2022 Report Share Posted February 8, 2022 30 minutes ago, irvin said: LTR6AHX ? Yes. 2013 FORD EDGE 3.5L V6 Spark Plug | RockAuto As WWWPerfA_ZN0W mentioned, the life span of the original Iridium plugs is also very good. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted February 12, 2022 Report Share Posted February 12, 2022 Motorcraft are rated at 100k miles. Can't go wrong with OEM. Quote Link to comment Share on other sites More sharing options...
DILLARD000 Posted February 25, 2022 Report Share Posted February 25, 2022 (edited) Been running AutoLite xp5364 Iridium Plugs in a 2008 3.5L for a year now with good results. These replaced MotorCraft# ayfs22fm \ sp411 Platinum Plugs which also performed well. Be sure to check OwnersManual for proper OEM part & gap, then cross reference from that. Be sure to check+adjust gap as needed before install; do NOT assume they're gapped correctly. Edited February 25, 2022 by DILLARD000 Quote Link to comment Share on other sites More sharing options...
