Black and White Posted December 7, 2008 Report Share Posted December 7, 2008 Is anyone else getting a high pitch sound when the engine is running?, I only hear it when I am outside the CUV, not while I am inside. Quote Link to comment Share on other sites More sharing options...
818EDGE Posted December 8, 2008 Report Share Posted December 8, 2008 Probably the fuel pump. Depends on how high pitch. Quote Link to comment Share on other sites More sharing options...
Black and White Posted December 11, 2008 Author Report Share Posted December 11, 2008 Probably the fuel pump. Depends on how high pitch. I just hit 1000 km, or 610 miles, fuel pump already??? Quote Link to comment Share on other sites More sharing options...
Waldo Posted December 11, 2008 Report Share Posted December 11, 2008 It doesn't mean the fuel pump is bad, it's just an inherant characteristic of the relationship between the pump and the tank. Some are worse than others, but it's nothing to worry about. Quote Link to comment Share on other sites More sharing options...
Charlie Harper Posted January 5, 2009 Report Share Posted January 5, 2009 My original fuel pump was replaced on my MKX at about 6,500 kms (Engine would shut off while driving - but only immediately after the tank was filled with gas). This pump was making a high pitched whine intermittently. The replacement pump is much worse and whines constantly. If you have good hearing you can easily hear it. It is very annoying since it sounds like you have a ringing in your ears. My dealership has confirmed this problem and contacted Ford but they stated that Ford told them that the pump is working as designed and will not do anything about it. Quote Link to comment Share on other sites More sharing options...
jak508 Posted January 26, 2009 Report Share Posted January 26, 2009 Thanks for the information folks, I thought I was losing my mind. My 07 MKX started making the high pitched whining sound intermittently starting back in October 08. You can definitely hear it inside the cabin and outside the car when it occurs. Never would have thought it was the fuel pump since I have never owned a car that the pump made that kind of noise or any noise for that matter. I thought it was something in the rear of the vehicle because that is where I thought the noise originally was coming from when I first noticed it. Quote Link to comment Share on other sites More sharing options...
barbieann Posted February 5, 2009 Report Share Posted February 5, 2009 Thanks for the information folks, I thought I was losing my mind. My 07 MKX started making the high pitched whining sound intermittently starting back in October 08. You can definitely hear it inside the cabin and outside the car when it occurs. Never would have thought it was the fuel pump since I have never owned a car that the pump made that kind of noise or any noise for that matter. I thought it was something in the rear of the vehicle because that is where I thought the noise originally was coming from when I first noticed it. I am going to cross post here. Read the any one have a whining noise? on the 08Edge and MKX board. We all seem to be talking about the same thing. Quote Link to comment Share on other sites More sharing options...
asdashha Posted April 8, 2009 Report Share Posted April 8, 2009 It doesn't mean the fuel pump is bad, it's just an inherant characteristic of the relationship between the pump and the tank. Some are worse than others, but it's nothing to worry about. ------------------------------------------- new york escort Quote Link to comment Share on other sites More sharing options...
