2008 edge crank but no start next day starts fine no codes
PU Pink55
Last night my 2008 Edge 3.5L would crank but not start.  I had it towed home. This morning I go out to read code but try to start it first, vehicle started fine.  Checked codes and there are none.
Code reader Autel AL519
It was 40 degrees last night battery is good engine cranks over fine but would not start.
Edited by PU Pink55
update
There can literally be many reasons,  pulling the stored codes is best to narrow it down.
One possibility is the anti-theft system didn't recognize your key (the night before). The cause (possibily) is your cars  battery is getting weak and the voltage dropped low. Have a battery load test run to be certain (not voltage test, a load test, one that reads the capacity of the cranking amps or cold cranking amps). Less than 50% of the rated capacity is a battery that needs replacing.
If it is the anti-thief, try a reset. Put the key in the ignition and turn on (not start). Leave in the on position for several minutes to recognize the key. Then try to start. Another way is to put the key in the door, turn slightly, but not to the unlock position. Leave it for a minute or two then turn the opposite direction and leave for a minute. Then try starting.
