Dave C Posted January 20, 2022 Report Share Posted January 20, 2022 Good Morning folks. I'm having an issue with my 2016 Edge Sport 2.0 Diesel. 99,000klm The past couple of times I have been cruising at motorway speed (120kph) for a long period (over 1hr) and go to overtake a slower car and accelerate the temperature gauge goes up into the red. Bit of a loss of power too Now this first happened before Christmas just after I bought the car and it went into limp mode. I pulled over on the motorway and restarted the car and it was back to normal. The mechanic replaced the thermostat housing as he was told by ford that that was a common problem. I hadn't driven it in those conditions again until last night. Same issue again. Temp gauge raises when over 120kph but when back to cruise again it comes back down to normal? The timing belt and water pump have been changed before I got the car and that was all checked when it was in the garage a couple of weeks ago. I'm baffled as I can drive around off the motorway with heavy acceleration and nothing happens, but light acceleration at the higher speed causes the problem. Any Idea's? Thanks Dave Quote Link to comment Share on other sites More sharing options...
Cerberus Posted January 20, 2022 Report Share Posted January 20, 2022 generally speaking, if you overheat at highway speeds, its low on coolant, or the water pump is freewheeling (belt slip or loose impeller), or the radiator is internally obstructed. some cooling systems can trap air if not bled correctly after being low 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 20, 2022 Report Share Posted January 20, 2022 have had at least one owner report having to have the radiator replaced in a Euro Edge, for a leak not an obstruction tho. so may want to have it thermally imaged to check for obstructions as Cerberus mentioned. are the cooling fans coming on as designed when temps exceed set point? Quote Link to comment Share on other sites More sharing options...
Cerberus Posted January 20, 2022 Report Share Posted January 20, 2022 On 1/20/2022 at 2:58 PM, WWWPerfA_ZN0W said: are the cooling fans coming on as designed when temps exceed set point? Expand In theory, fans are irrelevant at highway speeds if the vehicle has any aerodynamic flow, but admittedly some do not. Usually if it will not overheat at around-town speeds but does overheat on the highway, the fans are not the problem. Quote Link to comment Share on other sites More sharing options...
cds71 Posted January 20, 2022 Report Share Posted January 20, 2022 ....any loss of coolant? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted February 26, 2022 Report Share Posted February 26, 2022 Sounds to me what your describing is air entrapment in the cooling system. (Runs fine when in city traffic, overheats on acceleration. Circulation failure under load). Quote Link to comment Share on other sites More sharing options...
