Rough Idle When Cold/P0301 Code - coolant intrusion - TSB 22-2133 & TSB 22-2229
Ronald S Katz
  • 1004ron changed the title to Rough Idle When Cold/P0301 Code - coolant intrusion - TSB 22-2133
On 6/26/2022 at 8:25 AM, Pam LCB said:
I am currently having the exact same issue with the same model and year.  I’m curious what was the solution?
10 hours ago, Pam LCB said:
I don’t have an Eco boost engine.  The water pump has been suggested, I’m more inclined to think computer or drive train related. Putting the car in neutral will bring the temp gauge down to normal.  It’s definitely a head scratcher
You posted in the "2.0L EcoBoost" section.
So what model and year do you have.
What are the issues you're having and what have you looked at?
  • 4 weeks later...
Add another one to the list.  2016, just turned 70K miles, and thankfully got the Carmax Maxcare warranty.  Maintained to a tee like all my cars.  Had a rough idle, and then a day later a CEL.  Opened the hood and was astounded to find the coolant resevoir almost empty.  Pulled codes and got the P301, then looked on here and knew I had an issue.
Must have started pretty quickly - I always eyeball the coolant tanks when checking oil, etc under the hood.  It's been at the Ford dealer for 8 days, still waiting for the Maxcare warranty inspector to go visit and confirm it's toast (Dealer said they have to do this all the time).
Update - was out of commission for 3 weeks at the Ford dealer but just got it back with a new 2022 Valencia produced long block.  Thanks to Carmax warranty was $300 instead of the $7,940 total on the 6 page bill.
  • Like 4
  • 5 weeks later...
My wife’s 2019 Ford Edge Ecoboost was sputtering during acceleration between the 1500 and 2300 RPM range in traffic.  I changed the spark plugs thinking that may help.
Now, the car idles rough, acts like it wants to die, and smells like rotten eggs from the exhaust.
Any suggestions??
1 hour ago, Edgy2019 said:
Thanks for the reply.   I don’t have any error codes or a CEL.  I just tried starting it again after leaving the battery unplugged for the day (not that it would help) and it smells like it’s running rich.
What did you use to check for codes?
Don't need the CEL on for codes to be stored.
What's the mileage and is still under warranty?
That same thing happened to me with my 2015 Escape at about the same mileage. If you frequent a Ford dealer go there first or go where you bought the car if it was a Ford dealership. They get $ from Ford to use for good customers for things like this. Then call corporate and talk to them about this. We did both of these things and because we are long time Ford owners (they can look it up and see) they worked with us and we were only out of pocket $2500. Not $0 but a lot less than the original. I just bought a 2021 Edge, I hope this doesn’t happen again! ?
I have a 2018 Edge 2.0, 80k miles in my shop with the water intrusion issue. Low compression on #4. I understand the issue was resolved with the 2020 model year engine. I have a question, perhaps for a Ford tech.  Can I replace the engine with a 2020  model from a wrecked vehicle?  Is the long block assy the same externally?, What compatibility issues might I face?   I have searched and can not find the info.
Thank you.
I have a 2019 Edge SE that has been giving me problems since day one. I took it in 2 weeks after i bought it because it didnt sound good, they change some high pressure fuel thing, explained that is was still doing the same thing and getting worst. I have had several open tickets on it with manufacture and never anything was always told that it is normal. However here we are in 2022 and now its so bad that it keeps throwing a power train malfunction wrench on the dash and my ford pass app is telling me that my cars health check is all good and the fluid levels are all ok but they are not because the coolant level has been going down for months and there is no leak and now the car is idling high so it jerks when going form park to reverse and when driving the car shifts so crazy and the rpm gauge is moving up and down. Can anyone tell me what i should do i feel like im at my whits end with ford
Depending upon the Diagnostic Trouble Codes (DTCs) involved in triggering the Malfunction Indicator Light (MIL), and whether your Edge is exhibiting any white smoke/steam out of the tailpipe which may be related to the low coolant condition, you may want to print this Technical Service Bulletin (TSB) and take it with you to the dealership...
Document download linkTSB 20-2234 - 2.0L EcoBoost - Illuminated MIL With Various DTCs, Low Coolant Level, White Smoke From Tailpipe, External Coolant Leak.pdf
Good luck!
  • Thanks 1
  • 1004ron changed the title to 2019 Ford Edge SE Malfunction
