How to Remove the Cargo Side Panel
Removal description and side panel illustration from the 2016 Edge Workshop Manual...
Good luck!
Position aside the liftgate weatherstrip, release the clips and remove the liftgate scuffplate trim panel.
Removal Illustration For Liftgate Sill Scuffguard Trim - 2016 Edge Workshop Manual.jpg
Release the clips, disconnect the electrical connectors and remove the loadspace trim panel.
Edited by Haz
Not sure what link you are referring to, though I did make an edit, so perhaps you were accessing the post while my edit was in progress.
The removal descriptions and illustrations should now be fully visible in my prior post.
If you click on either illustration, you should be able to save it locally and/or print it separately for reference.
Good luck!
Edited by Haz
