Will these fit without rubbing? 2019 Edge ST
Kbeck59
I’ve has em on for about two weeks now and absolutely LOVE the look and even more importantly the HUGE  change in the way my ST handles  and sticks to the corners and curves . It’s a night and day improvement over the stock OEM  20 inch wheels and junk Hankook tires
My new shoes are :
Ferrada Wheels FR2 , 20x10.5 , 5x108 +38 offset
Continental DWS06 Plus Extreme Contact  295/45/20
NO rubbing & a PERFECT Fit ....
#MEATY
Edited by Kbeck59
Spelling
  • Like 10
  • 7 months later...
  • 7 months later...
My new shoes are :
#MEATY
Your setup looks AWESOME!  The concave look is what I am looking for.
Thank you for sharing!
  • 10 months later...
I know it’s been awhile since there has been any responses on the ford edge posted by Kbeck59 but if you happen to get this did your install require any spacers? And did all the center caps snap in without hitting the spindle? Thanks for the info. The tires and wheels look great.
  • 5 months later...
Great set up !!!
I have a 2012 explorer limited with 295/45 R20 mounted on its OEM 20 inch rim (5 spoke)  Ive had that setup for now 10 years with no problems.
I recently got a 2019 Edge ST with its 5 spoke original 20 inch rims, but it came with 245/50 R20 tires, according to tire size calculator, I can go with 285/40 R20 and it would be 1% bigger that the original overall size..... but can the original 20 inch rims from the ST handle the 285 wide tire ?
Thanks
  • 9 months later...
Hi there, I have a 2019 Edge ST and wanted to get a new set of wheels. I saw this guy running 20x10.5 et38 Ferrada FR2 with 295/45/20 and he said there was no rub and perfect fit. I was curious if I'd need to modify anything for them not to rub or if they'd not rub just being mounted on regularly. I don't care that they poke out of the wheel well. That is the look I am going for. Thank you!
Did you ever find out? Or run a similar setup
My new shoes are :
#MEATY
Any spacers you needed to run or fenders needed to be rolled? Or just didnt rub at all stock suspension?
Using the correct tire calculator, the system will tell you what will and what won’t fit.
You will need to do some measuring related to wheel depth, tire clearance, etc. to get a baseline for fitment.  The calculator system has all the simple directions to complete the calculations.
Once you establish the baseline, you can play with the numbers and get your answer.  You can get new wheel size and offset as well as tire size.
Whatever tire size you choose, keep the overall tire diameter the same, or as close as possible to, the OEM tire size so you don’t negatively affect your speedometer or AWD system
