millstreamparlee Posted January 3, 2022 Report Share Posted January 3, 2022 Hi all, I have a 2008 Edge Limited. Works great. The only issue I have is the interior lights do not turn on when you open the door or turn them on with the dash switch. -The puddle lights under the mirrors work, which confirms the door open switch is working. -You can push the switch on the map light and it works. -I can't find any blown fuses. (4, 12, 10) all good. -I swapped the bulbs around to confirm they are good. Any help would be greatly appreciated. Thanks, Chris Quote Link to comment Share on other sites More sharing options...
millstreamparlee Posted January 6, 2022 Author Report Share Posted January 6, 2022 Anybody???? Quote Link to comment Share on other sites More sharing options...
Haz Posted January 6, 2022 Report Share Posted January 6, 2022 (edited) Below are download links to PDF versions of relevant sections of the 2008 Edge Workshop Manual. If your diagnostic actions create a need for specific connector diagrams and/or location illustrations, let me know and I will gladly supply them. Good luck! Interior Lighting Description and Operation - 2008 Edge Workshop Manual.pdf Interior Lighting Diagnosis and Testing - 2008 Edge Workshop Manual.pdf Edited January 6, 2022 by Haz 2 Quote Link to comment Share on other sites More sharing options...
millstreamparlee Posted January 6, 2022 Author Report Share Posted January 6, 2022 Thank you! Quote Link to comment Share on other sites More sharing options...
