New member, 2007 Ford Edge SEL Plus
UnholyDjMiku
Hello, im new to the forum, 3rd owner of a 2007 Edge with 210k on the clock, bought it with 190k. All tips, tricks, and informative Advice are all welcome. Down the road i plan on swapping in a high output 3.5l v6 ecoboost and converting the drivetrain to AWD. some lowering springs, do some custom lightning and rims followed by an exhaust. Its currently Na and within the next couple months i plan on going somewhere local and getting it tuned om the factory PCM.  Yes ik this car is not meant to have a turbo engine put in, ive already accepted the custom fabrication and wiring that will go into the swap, again if anyone has advice feel free to drop it below in the responses/comments.
Edited by UnholyDjMiku
welcome, nice ride.
note that 3.5EB will be a difficult job without some massaging of the frame and body.  the transverse version is too wide to fit in the current config/space, and the longitudinal version, well, needs more room up front.  might be better off putting in a 2.7 or 3.0 EB.
if retaining the current engine, you can watch videos on the Edge on YT ... my sig gives you some ideas.
