2008 edge sel OVERDRIVE issues
DEC
My 2008 Ford Edge has issues with the overdrive portion of trans.  Trans world perfectly in the first 4 gears, no hunting or jerking. Under normal operation the overdrives kick in and out when going up a slight grade and while cruising at, lets say 50 mph, and you step on the gas the overdrives also kick in and out. It appears to be worse when in is raining or very damp atmosphere. Driving without overdrive there is absolutely no hesitation between gears.
Does anyone have this problem and know what the fix may be?
Thanks in advance
David
Recently changed Plugs in my 2008 EdgeAWDSEL V6~3.5L~DOHC
from stock Platinum FordMotorCraft# ayfs22fm\sp411
to Iridium AutoLite# xp5364
with good results, running 10kMiles since.
Cleaned+OhmChecked the Coils while I was there.
If no Transmission Drain+Refill in the last 33kMiles, consider that.
Awhile back switched ATF
from stock MerconV Fluid
to AmsOil# SSMV
with good results; shifts smooth+quick.
Edited by DILLARD000
