Mi2013edge Posted December 5, 2021 Report Share Posted December 5, 2021 After I replaced both headlamps on my ‘13 Edge, the auto headlamp feature stopped working. I went through the owners manual and the procedure for headlamp delay - still nothing. How do I fix this? 1 Quote Link to comment Share on other sites More sharing options...
ben senise Posted December 6, 2021 Report Share Posted December 6, 2021 are you saying that you replaced the whole unit or did you just replace the bulbs? did you exchange like for like? 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted December 6, 2021 Report Share Posted December 6, 2021 Guidance from the 2013 Edge/MKX Workshop provided via underlined PDF download links. Good luck! Autolamps Diagnosis and Testing - 2013 Edge-MKX Workshop Manual.pdf Autolamp Wiring Diagram 1 - 2013 Edge-MKX Workshop Manual.pdf Autolamp Wiring Diagram 2 - 2013 Edge-MKX Workshop Manual.pdf Autolamp Wiring Diagram 3 - 2013 Edge-MKX Workshop Manual.pdf Autolamp Wiring Diagram 4 - 2013 Edge-MKX Workshop Manual.pdf 2 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted December 7, 2021 Report Share Posted December 7, 2021 Did you replace with the correct bulbs? *Circuit may be current sensitive). Quote Link to comment Share on other sites More sharing options...
Mi2013edge Posted December 7, 2021 Author Report Share Posted December 7, 2021 I replaced the bulbs, not the entire unit.As far as I know they’re the correct bulbs Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted December 8, 2021 Report Share Posted December 8, 2021 Sounds silly, but must be asked, anything covering the light sensor on the top of the instrument panel? 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 8, 2021 Report Share Posted December 8, 2021 did you replace with bulbs of the same type (halogen for halogen or HID for HID) or change to LED or ...? with "cheap" product, the BCM can be sensitive, as lighting is based on PWM. so if the bulbs are not correctly designed, they can cause the automatic feature to fail. but will continue to work when you force it to ON. Quote Link to comment Share on other sites More sharing options...
Mi2013edge Posted December 8, 2021 Author Report Share Posted December 8, 2021 I thought about that and checked lol… Quote Link to comment Share on other sites More sharing options...
