rac8006 Posted October 13, 2021 Report Share Posted October 13, 2021 The passenger mirror glass popped out in the car wash. The mirror heater wires came loose. I found that the wires seem to be DC one + and one -. Do the wires need to be put back in a certain order? Since the heated core is basically a short I would think it doss not matter. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
CARR142 Posted October 13, 2021 Report Share Posted October 13, 2021 Doesn't matter. Quote Link to comment Share on other sites More sharing options...
rac8006 Posted October 14, 2021 Author Report Share Posted October 14, 2021 I kind of thought so. Plus the wires seem to have a memory. They line up with the pins when you put the mirror in place. Now I need to find out why the bliss is not working. I've had the mirror off a few times becasue most of the clips are broke. which is why it fell out. Some times after putting it back it works sometimes it fails. It is only one connector. Not sure why this is happening. Quote Link to comment Share on other sites More sharing options...
rac8006 Posted October 14, 2021 Author Report Share Posted October 14, 2021 Fixed the problem with the bliss. It was a bad connection. I connected and disconnected the bliss connector several times and now it works. 2 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted October 15, 2021 Report Share Posted October 15, 2021 Bet the contacts are corroded. When you made and remade to connection you scraped enough corrosion off to remake the contact. Probably won't last however, corrosion likes to grow. Suggest you spray contacts with a cleaner specifically designed for this. Cleans then protects. Here's what I recommend: https://www.amazon.com/dp/B000BXOGNI/ref=cm_sw_r_apan_glt_fabc_500CTHFZ8CDF3HP4Z9M6 Quote Link to comment Share on other sites More sharing options...
