Ford edge issues - Android screen not working
  • 1004ron changed the title to Ford edge issues - Android screen not working
Whenever you change the OEM head unit to an aftermarket unit, there's always a possibility that the new unit will not connect with the Ford Sync.
It's also possible that you need to purchase a special wiring harness or module, to activate the missing features.
If the manufacturer indicated that their unit does work with Ford Sync, try contacting them to see if a special wiring harness is needed. If they didn't, it may not have been designed to work with those functions and you have no options other to live with it or put the OEM unit back in.
