itsnotdustin Posted September 30, 2021 Report Share Posted September 30, 2021 (edited) I have a 2018 Edge Sport with the Sony system. I have a line output converter (LOC) tapped into the subwoofer wires. I have a Skar 1500w amp and 4 10s. The problem: Every time I turn my car on, the subwoofers pulse 3 times. It's a slow but loud pulse/hum. I'm pretty sure it is an issue with the LOC, but before I cut it out and replace with another one, I wanted to see if anyone else has had this issue. I'm using this LOC - https://www.sonicelectronix.com/item-40540-NVX-XFLOC2.html Here is the install post for reference - Update: I ordered an Audiocontrol LC1i.....we will see if that fixes the problem. Update 2: I installed the Audiocontrol LC1i and it didn't fix the issue. With more research I found a post saying the ANC (active noise cancelling) could be the issue. Well I opened Forscan, pulled up the DACMC module, and disabled both ANC and Engine Enhancement. Problem solved. https://www.forscan.org/forum/viewtopic.php?t=8413 Edited October 3, 2021 by itsnotdustin Quote Link to comment Share on other sites More sharing options...
