Mike422 Posted September 24, 2021 Report Share Posted September 24, 2021 This morning I got in my edge and there was no audio coming from the speakers when set on a preset channel. So I tried others preset AM & FM with no luck. Then I tried Bluetooth and USB and no luck. Tonight I got home and removed the fuse for the radio and reset it and no luck. I went into diagnostic mode (CD Eject & Seek >>>) and did the audio test NO Luck. Is there a separate fuse I am missing? Any Ideas? Quote Link to comment Share on other sites More sharing options...
Mike422 Posted September 25, 2021 Author Report Share Posted September 25, 2021 I was able to fix the problem described above by updating the SYNC app in the ACM. Here is a video that will walk you thru the steps of updating. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 25, 2021 Report Share Posted September 25, 2021 (edited) Car off. Go to your fuse panel (in cabin) and remove the power feed for 10 seconds). Then plug the power feed back in. Start car and see if you have sound. Found youtube video to show you how. Edited September 25, 2021 by enigma-2 Add video Quote Link to comment Share on other sites More sharing options...
