Hardwire radar detector
  • 2 years later...
Get a flashlight (preferrably one you can hold in your mouth), an adjustable wrench and (possibly)some wire strippers
Tap the fuse on #35. (You can get an official 'fuse tap' from Radio Shack for less than $5, or just stripped the wire, pull the fuse, wrapped wire around one side of the fuse and put the fuse back in.. )
Now run the other wire (Neg) to somewhere on the frame. ..I found a bolt that I loosened and jammed the wire behind and re-tightened.
Now run wire up door seal to A pillar trim (the hard plastic piece that is between your door and windshield). tuck behind A pillar trim up to the headliner. tuck wire up behind headliner and run to detector. Takes about 5-10minutes.
