Special_K Posted September 9, 2021 Report Share Posted September 9, 2021 Yea you read that right, 570whp edge! new platform record! we ran out of fueling at 5500ish rpm (redline is 6450) and it pulled boost (25psi to 23psi). Waiting on a new hpfp pump and injectors and we should easily see 600whp! 8 Quote Link to comment Share on other sites More sharing options...
bryantgbell Posted September 9, 2021 Report Share Posted September 9, 2021 Awesome!!! So New HPFP? If you're unloading your old one let me know! 1 Quote Link to comment Share on other sites More sharing options...
Special_K Posted September 9, 2021 Author Report Share Posted September 9, 2021 On 9/9/2021 at 12:21 PM, bryantgbell said: Awesome!!! So New HPFP? If you're unloading your old one let me know! Expand Dont know yet, XD-i may want to trade. if not we will let you know! 1 Quote Link to comment Share on other sites More sharing options...
Xtra Posted September 10, 2021 Report Share Posted September 10, 2021 (edited) That is an amazing amount of power, congratulations, you are way over 600 hp at the crank. In fact, the stock Sport has 315HP at the crank and you have doubled that and then some .. I noticed that the dyno in the photo is FWD. Did you disconnect the rear wheels some how? Without a doubt you have the worlds fastest Edge, and I see a 11 second pass and another world record in your future. Edited September 10, 2021 by Xtra 3 Quote Link to comment Share on other sites More sharing options...
itsnotdustin Posted September 14, 2021 Report Share Posted September 14, 2021 (edited) This is insane. Do you have any in-depth build lists or video of your setup? I'm curious was the limits of this engine are. Is this a stock internals motor? There's no telling how far you can push an iron block. Edit: I just saw your sig with the 3.0tt swap which I guess is aluminum? I just learned about the 2.7 being a CGI block. Didn't realize a swap was an option. Crazy how much modding you can do to a crossover. Edited September 14, 2021 by itsnotdustin 2 Quote Link to comment Share on other sites More sharing options...
Special_K Posted September 16, 2021 Author Report Share Posted September 16, 2021 On 9/10/2021 at 7:44 PM, Xtra said: That is an amazing amount of power, congratulations, you are way over 600 hp at the crank. In fact, the stock Sport has 315HP at the crank and you have doubled that and then some .. I noticed that the dyno in the photo is FWD. Did you disconnect the rear wheels some how? Without a doubt you have the worlds fastest Edge, and I see a 11 second pass and another world record in your future. Expand Yea thats all they had available for right now and we wanted a benchmark just to see where we are before we figure the fuel out, so we disconnected the driveshaft. Once we figure out the rear coupler we will be hitting up the track for sure! On 9/14/2021 at 1:57 PM, itsnotdustin said: This is insane. Do you have any in-depth build lists or video of your setup? I'm curious was the limits of this engine are. Is this a stock internals motor? There's no telling how far you can push an iron block. Edit: I just saw your sig with the 3.0tt swap which I guess is aluminum? I just learned about the 2.7 being a CGI block. Didn't realize a swap was an option. Crazy how much modding you can do to a crossover. Expand Thanks man! most of the engine parts are in the sig, this whole build is done on stock internals and the point of it is to the capabilities of the platform without cracking open the engine. even though ford says the 3.0 is aluminum it is not. side by side the 2.7 and 3.0 have the same CGI section of the block and the 3.0 is ever so slightly lighter due to being bored im assuming. The 3.0 is a straight drop in and only need the oil pump parameters changed since its different from the 2.7. 4 Quote Link to comment Share on other sites More sharing options...
Markham12 Posted September 16, 2021 Report Share Posted September 16, 2021 (edited) That is an awesome build. I would buy a vehicle with those numbers for sure. That is approaching trackhawk numbers, which is my dream suv. Someday perhaps. AWD vehicles are fun. Edited September 16, 2021 by Markham12 2 Quote Link to comment Share on other sites More sharing options...
cds71 Posted November 22, 2021 Report Share Posted November 22, 2021 is the 3.0 both port and direct injection? Quote Link to comment Share on other sites More sharing options...
Special_K Posted January 10, 2022 Author Report Share Posted January 10, 2022 On 11/22/2021 at 9:19 PM, cds71 said: is the 3.0 both port and direct injection? Expand Just Direct injection Quote Link to comment Share on other sites More sharing options...
snmjim Posted January 12, 2022 Report Share Posted January 12, 2022 (edited) On 9/16/2021 at 11:20 PM, Markham12 said: That is an awesome build. I would buy a vehicle with those numbers for sure. That is approaching trackhawk numbers, which is my dream suv. Someday perhaps. AWD vehicles are fun. Expand Well here's your lucky opportunity, it just went on the market, make us an offer you just might be surprised! it's fully bolted with a stock 3.0 TT eco boost and everything in the car is in pristine condition and a fully functional reliable daily driver...??? 584 whp & 600+ lbs of AWD torque and continues to get 29 +/- mpg Hwy cruising at 65-70 mph...??? Edited January 12, 2022 by snmjim 3 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 12, 2022 Report Share Posted January 12, 2022 argh! we are not ready yet to buy i have seen this Edge in person, and it is everything that has been posted about, in words, pictures, and videos. 1 Quote Link to comment Share on other sites More sharing options...
snmjim Posted January 12, 2022 Report Share Posted January 12, 2022 (edited) On 1/12/2022 at 4:51 PM, WWWPerfA_ZN0W said: argh! we are not ready yet to buy i have seen this Edge in person, and it is everything that has been posted about, in words, pictures, and videos. Expand . Thank You Manu for your support! Edited January 12, 2022 by snmjim 1 Quote Link to comment Share on other sites More sharing options...
Xtra Posted January 12, 2022 Report Share Posted January 12, 2022 (edited) I am sorry to see you moving on from the Edge platform. When you first started this journey there were few if any performance parts available for the Edge. You have pushed it to the max and given the Edge community a plethora of bolt on performance parts to work with. Your legacy will live on as a leader of the Edge performance community. Thank you both snmjim and Special_K for all you have contributed. You guys rocked it with a world record that will stand for decades ! Edited January 12, 2022 by Xtra 4 1 Quote Link to comment Share on other sites More sharing options...
snmjim Posted January 27, 2022 Report Share Posted January 27, 2022 On 1/12/2022 at 10:05 PM, Xtra said: I am sorry to see you moving on from the Edge platform. When you first started this journey there were few if any performance parts available for the Edge. You have pushed it to the max and given the Edge community a plethora of bolt on performance parts to work with. Your legacy will live on as a leader of the Edge performance community. Thank you both snmjim and Special_K for all you have contributed. You guys rocked it with a world record that will stand for decades ! Expand Thnx best coast Brother for your kind words of appreciation & recognition. Just want to reassure everyone that we're not gone and can be reached via the forums and Instagram PM systems. Stay tuned on our projects progress via Instagram @ fastest_edge Across the ground or falling from the sky, everything at terminal velocity & beyond??? 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 27, 2022 Report Share Posted January 27, 2022 well, can definitely pray for soft landings lol. if you're not moving, you're d..d. On 1/27/2022 at 2:13 PM, snmjim said: Across the ground or falling from the sky, everything at terminal velocity & beyond??? Expand 1 Quote Link to comment Share on other sites More sharing options...
Markham12 Posted March 2, 2022 Report Share Posted March 2, 2022 On 1/12/2022 at 4:31 PM, snmjim said: Expand On 1/12/2022 at 10:31 AM, snmjim said: Well here's your lucky opportunity, it just went on the market, make us an offer you just might be surprised! it's fully bolted with a stock 3.0 TT eco boost and everything in the car is in pristine condition and a fully functional reliable daily driver...??? 584 whp & 600+ lbs of AWD torque and continues to get 29 +/- mpg Hwy cruising at 65-70 mph...??? Expand That would have been an insane ride for my daily driver. But I would not have a license long with that much power. Hope you found a buyer. 2 Quote Link to comment Share on other sites More sharing options...
