Icewiley Posted August 31, 2021 Report Share Posted August 31, 2021 Hi. I just bought a 2013 Edge w/72,000 miles on it. The dealership said that they replaced both the front and back brakes. I have had to refill the brake fluid reservoir 3 times in two weeks. The dealership says that it’s a bad ABS module but I can’t find anything that says leaking brake fluid is a sign of a bad module. The ABS warning light has never come on either. Thank you for your help!! 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 31, 2021 Report Share Posted August 31, 2021 The source of the leak could be any one of the many brake components (calipers, master cylinder, ABS unit, ........), and without an inspection there's no way of knowing. 1 Quote Link to comment Share on other sites More sharing options...
jmr061 Posted September 1, 2021 Report Share Posted September 1, 2021 10 hours ago, Icewiley said: Hi. I just bought a 2013 Edge w/72,000 miles on it. The dealership said that they replaced both the front and back brakes. I have had to refill the brake fluid reservoir 3 times in two weeks. The dealership says that it’s a bad ABS module but I can’t find anything that says leaking brake fluid is a sign of a bad module. The ABS warning light has never come on either. Thank you for your help!! Did they inspect it and then tell you that or just tell you that when you brought it up to them? If they didn't inspect it, they are just talking out of their ass. You keep having to add brake fluid....there is a leak somewhere. An inspection needs to be done. Now if they inspected it and determined the ABS module is where the leak is, either things need to be tightened up or the bad part needs to be replaced. Brakes are not something to mess around with. 3 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 1, 2021 Report Share Posted September 1, 2021 (edited) many things can leak. brake hoses at the calipers or at the M/C / hcu, or the M/C into the booster. so def make sure the system is properly inspected. btw, brake hoses original to the vehicle have almost NEVER been an issue on 2007-2014 MYs. However, replacements, even OEM sometimes, have been problematic once or twice, especially at the M/C. expect fluid level to go down in the reservoir as the pads wear. that is natural. what is not natural is sudden, large drops in fluid level. also, the fluid level should never be above the MAX line on the reservoir, except when performing a flush. Edited September 1, 2021 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
Icewiley Posted September 1, 2021 Author Report Share Posted September 1, 2021 I knew that brake fluid will go down over time and I wasn’t concerned the first time the warning light came on about the brake fluid being low since the brakes had just be replaced, I thought maybe the dealership didn’t bleed them properly but when I had to fill it up again a week later and then again two days later then I knew something was going on. I’m taking it to my regular mechanic to see what he finds. The service department at the dealership telling that they’d split the cost with me just seemed weird to me, like they were trying to cover up something that should have been caught during the initial inspection. Thanks your help! Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 3, 2021 Report Share Posted September 3, 2021 Years and years and years ago I had this happen to me. The mechanic didn't tighten the bleed screw properly. Quote Link to comment Share on other sites More sharing options...
1004ron Posted September 3, 2021 Report Share Posted September 3, 2021 On 8/31/2021 at 9:44 PM, Icewiley said: I knew that brake fluid will go down over time and I wasn’t concerned the first time the warning light came on That's only half correct - yes the fluid will go down just a little as the brake pads wear, but that will be no where near the low level warning. There was a few posts here a while back about dealerships not knowing the correct bleed procedure of the ABS unit. Quote Link to comment Share on other sites More sharing options...
