2013 2.0 eco boost - torque for oil feed tube bolts?
Corey 911
  • 1004ron changed the title to 2013 2.0 eco boost - torque for oil feed tube bolts?
NOTE: Make sure that 2 new linked washers are installed.
NOTE: Both water outlet tube clamps must be installed between the 2 paint stripes on hoses.
Tighten to 28 Nm (21 lb-ft).
NOTE: Make sure that 4 new turbocharger oil supply pipe gaskets are installed.
Tighten to 25 Nm (18 lb-ft).
NOTE: Make sure that a new turbocharger oil drain tube is installed. By not doing so, the turbocharger oil drain tube may leak and cause engine damage.
Tighten to 10 Nm (89 lb-in).
NOTE: Make sure that 4 new turbocharger-to-cylinder head studs, 4 new turbocharger nuts and a new turbocharger gasket are installed.
Tighten to 50 Nm (37 lb-ft) in the sequence shown.
Edited by WWWPerfA_ZN0W
  • 3 years later...
I can’t find the sequence that you referenced?
I am guessing I need to torque the studs first to the 37ft/lbs, then the gasket, turbo, then nuts.  When torquing the nuts do I make an X pattern?  Also, will I need to stage the torques like 20 ft/lbs,  30ft/lbs, then final 37ft/lbs?
