Edge 2016 Posted August 28, 2021 Report Share Posted August 28, 2021 So I have a 2016 3.5 V6 Edge with 91000 miles on it. Its been in the Ford servfice shop 5 times in 3 months to try and find this problem. So far the PTU, rear differential and the rear axel all have been replaced (still under drivetrain warranty). Still making the noise. Dealership said the rear differential was bad and making a noise as well but the replacement did not fix the issue. Anyone have any ideas? I guess they want to tear into transmission next. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 1, 2021 Report Share Posted September 1, 2021 (edited) can you tell the location of the noise? for example, fuel pump will come from the rear/hatch area. ptu will come from front passenger side. if you drive with windows up, you may want to lower them one at a time till you can more closely locate the sound. when was transmission fluid last serviced? can certainly be wheel bearings, so check if turning left/right makes a difference. check for air leaks in the engine bay. Edited September 1, 2021 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
Edge 2016 Posted September 1, 2021 Author Report Share Posted September 1, 2021 It sounds like it's coming from the front. No change if turning left or right. PTU has been replaced. No idea when trans fluid was replaced last. Bought it used. I have not replaced it since I have owned it. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted October 29, 2021 Report Share Posted October 29, 2021 https://www.knowyourparts.com/technical-resources/drive-train/diagnosing-differential-noise/#:~:text=A “whirring” noise while decelerating,bad ring and Pinion gear. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 29, 2021 Report Share Posted October 29, 2021 (edited) this is the only transmission related bulletin i can find that might possibly apply for your vehicle https://drive.google.com/file/d/1ska26YITryYl1aUdEGh7cswf74xLeg_h/view?usp=sharing i hope it is not this, as it is a serious matter, requiring transmission disassembly. could be the pump also. check the fluid to make sure it is pinkish red, at the right level, and clean. maybe just low fluid ... Edited October 29, 2021 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
Edge 2016 Posted October 29, 2021 Author Report Share Posted October 29, 2021 3 hours ago, enigma-2 said: https://www.knowyourparts.com/technical-resources/drive-train/diagnosing-differential-noise/#:~:text=A “whirring” noise while decelerating,bad ring and Pinion gear. Well since my first post the rear end has been replaced. The transmission has been replaced and the Power transfer unit has been replaced and it still is making the noise. Not as bad but it’s still there. The sound really sounds like it’s more in the front now. The dealership said there was damage to both the rear and the transmission. Transmission was tore apart and then replaced. This has all been under warranty. Warranty running out in about 7000 miles so I’d like to get this figured out soon. Dealership said they didn’t hear anything after the latest repair. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted October 31, 2021 Report Share Posted October 31, 2021 Does it still do it when decelerating from 40 mph with the transmission in neutral? Quote Link to comment Share on other sites More sharing options...
Edge 2016 Posted October 31, 2021 Author Report Share Posted October 31, 2021 No it does not Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted November 1, 2021 Report Share Posted November 1, 2021 When they replaced the rear end, did they replace all of it or reuse parts, such as bearings, etc.? Quote Link to comment Share on other sites More sharing options...
Edge 2016 Posted November 1, 2021 Author Report Share Posted November 1, 2021 All new parts. This is a ford dealership and it took about a month to get all the parts in. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted November 2, 2021 Report Share Posted November 2, 2021 WWWPerfA_ZN0W mentioned wheel bearings. One way to test this is to decelerate from 40 and swerve from side to side. This unloads the bearing on the side opposite the swerve and may notice the whine get louder of softer. 1 Quote Link to comment Share on other sites More sharing options...
Justin400 Posted November 21, 2021 Report Share Posted November 21, 2021 bro umm where did you get that differential from haha i’ve been waiting for some time now. Quote Link to comment Share on other sites More sharing options...
Justin400 Posted November 21, 2021 Report Share Posted November 21, 2021 On 11/1/2021 at 7:05 AM, Edge 2016 said: All new parts. This is a ford dealership and it took about a month to get all the parts in. What month did this all take place? my order has been in since August. Quote Link to comment Share on other sites More sharing options...
Edge 2016 Posted November 21, 2021 Author Report Share Posted November 21, 2021 7 hours ago, Justin400 said: What month did this all take place? my order has been in since August. Well the rear was August intro September and the transmission was early October. Took a month for transmission and 3 weeks for rear end to come in. Quote Link to comment Share on other sites More sharing options...
Edge 2016 Posted November 21, 2021 Author Report Share Posted November 21, 2021 11 hours ago, Justin400 said: bro umm where did you get that differential from haha i’ve been waiting for some time now. It took mine 3 weeks and it was a dealership. Quote Link to comment Share on other sites More sharing options...
Edge 2016 Posted November 21, 2021 Author Report Share Posted November 21, 2021 On 11/2/2021 at 6:58 PM, enigma-2 said: WWWPerfA_ZN0W mentioned wheel bearings. One way to test this is to decelerate from 40 and swerve from side to side. This unloads the bearing on the side opposite the swerve and may notice the whine get louder of softer. No bearing. That was checked and given the okay. Quote Link to comment Share on other sites More sharing options...
