Howdareyou Posted October 12, 2016 Report Share Posted October 12, 2016 Did anyone find a solution to this problem please help, also radio out and driver side power seat out Quote Link to comment Share on other sites More sharing options...
Howdareyou Posted October 12, 2016 Report Share Posted October 12, 2016 (edited) Can't find anything about how this problem was fixed Edited October 12, 2016 by Howdareyou Quote Link to comment Share on other sites More sharing options...
Nilton Posted July 29, 2018 Report Share Posted July 29, 2018 This happened to me 10 years ago. Only 10 days after I've purchased my Edge. It went back to the dealer, and after Day #4 they have narrowed it down to a module/junction that, roughly acts like a 'network hub' for all the sensors in the vehicle, and it is mounted just behind the steering wheel. But after Day #5 they finally found the culprit. Incredible as it seems, the Steering Position Sensor installed just behind the steeringwheel and adjacent of the turn-signal lever. For some strange reason, this sensor was wreaking havoc on the rest of the system, creating false warnings, and even disabling the airconditioning compressor. It was fixed in April 2008. Now it's July 2018, and my car is doing the same again. The Instrument Panel is behaving like a Christmas Tree Flashing everything. It's like you're in a Dancing Club. This time, I hope somebody can tell me that it is a DIY Fixable job. Quote Link to comment Share on other sites More sharing options...
Longlegg Posted March 13, 2021 Report Share Posted March 13, 2021 Did anyone ever figure out what was the problem with das board lights going off and on while driving my edge is doing it and the Ford dealer mechanic told me the lights would have to stay on before he could tell me what the problem is Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 14, 2021 Report Share Posted March 14, 2021 (edited) Is it random lights going on or off, or the same ones each time? I suppose no pics are available since these show up while driving ... flashing check engine lights are misfires, if that's any help. check for codes with an OBD scanner. you can DIY with a Veepeak $11 bluetooth device and Forscan Lite software for your smartphone/tablet. Edited March 14, 2021 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
fransua Posted August 15, 2021 Report Share Posted August 15, 2021 Every darn warning light would light up, sometimes more or less . But she is working fine . A couple of times has shut off like if gas is cut off. Otherwise drives wonderfully. I hate to drive around with all those lights on! Put new battery in and work fine for a hour or two! Please any info would appreciate thanks ahead Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 15, 2021 Report Share Posted August 15, 2021 Get the stored error codes read and post them here. Being an ST it should still be under warranty - best get it to a dealership. Please update your profile signature with your location and vehicle model and year - https://www.fordedgeforum.com/settings/signature/ Quote Link to comment Share on other sites More sharing options...
fransua Posted August 15, 2021 Report Share Posted August 15, 2021 I have a 2013 edge sel and having the same problem warning lights all of them lit up. Any help would be appreciated. Drives great but I hate those lights on. Ran diagnostic and all is ok. Please let me know if you find something out! Thanks Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 15, 2021 Report Share Posted August 15, 2021 On 8/15/2021 at 12:25 AM, fransua said: I have a 2013 edge sel and having the same problem warning lights all of them lit up. Any help would be appreciated. Drives great but I hate those lights on. Ran diagnostic and all is ok. Please let me know if you find something out! Thanks Expand You first posted in the ST section - moved here after you posted here as well. Please update your profile signature with your location and vehicle model and year - https://www.fordedgeforum.com/settings/signature/ Quote Link to comment Share on other sites More sharing options...
fransua Posted August 18, 2021 Report Share Posted August 18, 2021 On 3/14/2021 at 9:49 AM, WWWPerfA_ZN0W said: Is it random lights going on or off, or the same ones each time? I suppose no pics are available since these show up while driving ... flashing check engine lights are misfires, if that's any help. check for codes with an OBD scanner. you can DIY with a Veepeak $11 bluetooth device and Forscan Lite software for your smartphone/tablet. Expand In my case every warning lights up at al moment I disconet battery for a couple of minutes put it back and all is ok first 10 or 15 minutes then they lite up again , every warning light Quote Link to comment Share on other sites More sharing options...
fransua Posted August 26, 2021 Report Share Posted August 26, 2021 Hi there to all. I was working with my edge today and I found out a couple of things. I lent it for about a couple of weeks to my daughter. When it came back I noticed a red break warning on the right too plus all the warning lights. The edge is running perfect with no problem at all. I tried to reset doing all kinds of recomendaciones inclusive jumping the negative and positive desconected of course. Well I noticed then I had no fuse in the abs well put it in and reset again and nothing. As I turned the key all will go on immediately inclusive red sguare on right. I believe somebody when I lent the edge took it out. My question is as I put the switch on am I suppose to have 12v or any voltage on fuse connections I have not tried yet. Il try tomorrow. Quote Link to comment Share on other sites More sharing options...
omar302 Posted August 26, 2021 Report Share Posted August 26, 2021 On 8/26/2021 at 1:35 AM, fransua said: Hi there to all. I was working with my edge today and I found out a couple of things. I lent it for about a couple of weeks to my daughter. When it came back I noticed a red break warning on the right too plus all the warning lights. The edge is running perfect with no problem at all. I tried to reset doing all kinds of recomendaciones inclusive jumping the negative and positive desconected of course. Well I noticed then I had no fuse in the abs well put it in and reset again and nothing. As I turned the key all will go on immediately inclusive red sguare on right. I believe somebody when I lent the edge took it out. My question is as I put the switch on am I suppose to have 12v or any voltage on fuse connections I have not tried yet. Il try tomorrow. Expand For the brake light, did you check the brake fluid level or the fluid level sensor connector? If both are ok confirm that the float is actually up, not stuck down and giving a false warning. I would highly recommend you get ForScan with a suitable OBD adaptor as it can read diagnostic error codes from all modules, not just the PCM. It would greatly help you diagnose your Ford issues. Quote Link to comment Share on other sites More sharing options...
fransua Posted August 26, 2021 Report Share Posted August 26, 2021 Hi there again , I tried the voltage on the fuse and no voltage at all . I have not put the analyzer yet waiting for the check engine to light up. Last time I used it gave mi no codes at all. Does the fuse suppose to have voltage once I turn it on I think it should. And I did check fluid and flowter. I’m 60 years old and I have a good background with mechanics I built my first car from ground up at 16 years of age. But I am somewhat lost with so much electronics on newer cars. Thanks for help ahead. Quote Link to comment Share on other sites More sharing options...
pdohr001 Posted August 27, 2021 Report Share Posted August 27, 2021 Did anyone ever solve this? I am having this exact issue with it randomly Not starting getting lights in random Quote Link to comment Share on other sites More sharing options...
beanbooger Posted August 16, 2022 Report Share Posted August 16, 2022 Hi everyone, I think I'm seeing the same issue on a 2007 Edge. See the attached video. So far, I've searched and other than replacing the steering angle position sensor, I don't see any conclusive fix. Any updates from anyone? Thanks, Brian Dash lights.movFetching info... Quote Link to comment Share on other sites More sharing options...
