Kiestler Posted August 12, 2021 Report Share Posted August 12, 2021 AC works , turn the temp up and nothing happens. Cold air from any vent. Heater core is good it’s not that. What next? Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted August 13, 2021 Report Share Posted August 13, 2021 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 14, 2021 Report Share Posted August 14, 2021 Blend door actuator. Might be able to reset the module with the following procedure: Press and hold the climate control power button and the defrost button at the same time. Wait until the system turns off and then release both buttons. After that is done press the climate control power button again to start it up and the system should be reset. Quote Link to comment Share on other sites More sharing options...
