2015 Powertrain Control ECM
Randy15
That is very odd. Perhaps the Powertrain Control ECM needs to be properly calibrated with the correct firmware for your VIN.  It very well may be a programming issue.  Unless you know what you're doing I wouldn't suggest making any power train modifications using FORScan or any other OEM or aftermarket programmer.
I would suggest taking it back to wherever you had the work done and tell them your issue/ concern. It should be a relatively simple fix.
