Carp0331 Posted August 9, 2021 Report Share Posted August 9, 2021 The wife’s edge has developed an oil leak at the front of the vehicle. It appears to be coming for either an oil cooler or cooler hose possibly. It has covered the underside of the car. Are these known to have oil cooler issues or hoses that need to be replaced? Trying to track down where it’s coming from. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 12, 2021 Report Share Posted August 12, 2021 haven't seen any mentioned for the 3.5 platform, but there have been oddball leaks at transmission lines where they are rubbing (on older gen vehicles). oil pressure switch might be something to look at. if oil was recently changed, check to make sure the filter is on tight/not doublegasketed. you don't have hydraulic steering, otherwise i would have said power steering hose ... Quote Link to comment Share on other sites More sharing options...
Randy09 Posted August 12, 2024 Report Share Posted August 12, 2024 My mother's edge has the same problem. Quote Link to comment Share on other sites More sharing options...
