Heater/AC fan problem
FINFAN3DP
  FINFAN3DP said:
For the past couple months I've had a problem with my 07 edge, whereby the fan will be on one minute, then slow down, and then sometimes shut all the way off. Took it to the dealership and of course they couldnt' get it to do it. Anyone else have this problem?? Or know of a solution??
If yours has a cabin air filter, check to see if its plugged up. May not be the problem, but worth checking.
Do you have auto air, If so is it set to auto? that could be normal operation. If not it could be a bad motor, resistor or maybe ground connection.
