Tire size
1 hour ago, JavyEdge'13 said:
I also have a 2013 Edge Sport with 22" but I'm thinking about changing the rims to a 20" in order to install a thicker tread tires. Is this possible? Please advise. Thanks
Most likely yes.  Only concern is that the wheels clear the brake calipers and 20s are usually big enough.  Make sure to use the OEM 20” tire size.
