BobbyJohnson927 Posted July 14, 2021 Report Share Posted July 14, 2021 How big of tires can I get on my 2011 Ford Edge Sport stock height? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 19, 2021 Report Share Posted July 19, 2021 Tirerack.com lists the 265/40R22 as max. Try calling them at 888-541-1777 and see what they would recommend. Quote Link to comment Share on other sites More sharing options...
JavyEdge'13 Posted September 5, 2021 Report Share Posted September 5, 2021 I also have a 2013 Edge Sport with 22" but I'm thinking about changing the rims to a 20" in order to install a thicker tread tires. Is this possible? Please advise. Thanks Quote Link to comment Share on other sites More sharing options...
akirby Posted September 6, 2021 Report Share Posted September 6, 2021 On 9/5/2021 at 11:50 PM, JavyEdge'13 said: I also have a 2013 Edge Sport with 22" but I'm thinking about changing the rims to a 20" in order to install a thicker tread tires. Is this possible? Please advise. Thanks Expand Most likely yes. Only concern is that the wheels clear the brake calipers and 20s are usually big enough. Make sure to use the OEM 20” tire size. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 6, 2021 Report Share Posted September 6, 2021 On 9/6/2021 at 1:22 AM, akirby said: Most likely yes. Only concern is that the wheels clear the brake calipers and 20s are usually big enough. Make sure to use the OEM 20” tire size. Expand 245/50-20". I'd consider the Perrilli Scorpio AS Plus 3. Around $210/tire. Quote Link to comment Share on other sites More sharing options...
JavyEdge'13 Posted September 12, 2021 Report Share Posted September 12, 2021 Thanks for the advise gentlemen. I'm looking at installing the Toyo Open Country. I already have the Scorpio tires but those are performance tires...I want the All Season type. Quote Link to comment Share on other sites More sharing options...
