SteveC58 Posted July 7, 2021 Report Share Posted July 7, 2021 We bought this 2011 Edge used with 180,000 miles on it. Less than 400 miles later, the advancetrac warning came on a few minutes after the drive train seemed to begin to seize up. Car was running and driving well and then upon a short climb on a steep entrance ramp, it would not accelerate. I was merging into traffic when this happened. I got to 35mph with rpms over 4,000. It would not accelerate further. Drove at 35mpg, 4000 rpm for about 1.5 miles and pulled over. Car would not budge afterward in any gear. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 7, 2021 Report Share Posted July 7, 2021 scan for codes - may be an issue with a wheel speed sensor or tone ring. could be a seized caliper also, common if the slide pins are not regularly serviced. you can use an infrared thermometer to check if any of the rotors are hotter than the others, IF the car is driveable. Quote Link to comment Share on other sites More sharing options...
EddieHudson Posted July 7, 2021 Report Share Posted July 7, 2021 Did you check the transmission fluid? Quote Link to comment Share on other sites More sharing options...
Edgingage Posted July 7, 2021 Report Share Posted July 7, 2021 Did you change the transmisión fluid (right when you bought the used vehicle)? It's due @ around 125 000 miles... Quote Link to comment Share on other sites More sharing options...
