samxander Posted June 16, 2021 Report Share Posted June 16, 2021 i have a 2013 For Edge SE AWD, i bought it second hand, just changed the PTU recently. so the problem is that few months ago it started making weired noise when accelerating, the engine sound is very loud and i can hear like a friction noise from under the car it seems coming from passenger side but i'm not shure. what could be the possible reason of that? any clue is appreciated. i will try to record the sound. Quote Link to comment Share on other sites More sharing options...
Perblue Posted June 17, 2021 Report Share Posted June 17, 2021 Brakes? Wheel bearing? with an exhaust leak to top it all off? 1 Quote Link to comment Share on other sites More sharing options...
samxander Posted June 17, 2021 Author Report Share Posted June 17, 2021 i'm also suspecting exhaust leak, even if after a certain driving time, the noise disapears and car runs smoothly Quote Link to comment Share on other sites More sharing options...
Perblue Posted June 17, 2021 Report Share Posted June 17, 2021 Once it's warmed up the manifold might be expanding to seal the leak. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted June 25, 2021 Report Share Posted June 25, 2021 On 6/17/2021 at 5:26 AM, samxander said: i'm also suspecting exhaust leak, even if after a certain driving time, the noise disapears and car runs smoothly Expand Control arm or sway bar bushings can be noisy until the rubber gets hot and expands. What type of sound is it? If exhaust, you should be able to crawl under car just after starting and catch the leak. 1 Quote Link to comment Share on other sites More sharing options...
samxander Posted July 3, 2021 Author Report Share Posted July 3, 2021 well i took it to the mechanic, we are still checking the car, and he said maybe the engine or transmission mounts are bad and need replacing Quote Link to comment Share on other sites More sharing options...
samxander Posted July 7, 2021 Author Report Share Posted July 7, 2021 On 6/25/2021 at 8:45 AM, enigma-2 said: Control arm or sway bar bushings can be noisy until the rubber gets hot and expands. What type of sound is it? If exhaust, you should be able to crawl under car just after starting and catch the leak. Expand i have bad tie rods and a leaking front right axle, transmission mount is bad also, still have to check motor mounts. i will try to change these and see if the noise goes or not. Quote Link to comment Share on other sites More sharing options...
