Rockfish Posted June 11, 2021 Report Share Posted June 11, 2021 My 2018 Edge SEL has rain sensing wipers. 3 times over the past couple months while driving with the wipers in auto rain sensing mode, the wipers started and adjusted speed with the rain as they should but then stopped altogether. The wipers would not work in any setting-auto, low or high speed. I stopped the car turned the engine off and restarted and the wipers worked properly again. Have there been any recalls on this issue since if I am not able to quickly stop to restart the car, this could be a serious safety problem. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted June 12, 2021 Report Share Posted June 12, 2021 (edited) No recall that I've seen. See anything on this site helps isolate the problem. (Corrosion on the wiper stalk switch connector is a good first starting place). https://itstillruns.com/troubleshoot-rain-sensing-wipers-7591440.html Edited June 12, 2021 by enigma-2 Quote Link to comment Share on other sites More sharing options...
