hyperc32 Posted June 2, 2021 Report Share Posted June 2, 2021 So I bought new D3S replacements and noticed my 2015 sports Headlamps are different then what I have seen off the web... Starters no ballast under the headlamp 2nd the wire to the bulb is a different connector and to top it all off there is no plastic collar to unlatch the bulb just a metal one? Quote Link to comment Share on other sites More sharing options...
hyperc32 Posted June 2, 2021 Author Report Share Posted June 2, 2021 Quote Link to comment Share on other sites More sharing options...
hyperc32 Posted June 2, 2021 Author Report Share Posted June 2, 2021 Sorry if the photos are not the best, service manuals really don't help never been beat by a bulb before LOL... Not even sure what my next step would be housing and all even says D3S , can the headlamp housing be taken apart or is it glued.. I see 1 torx and like 7 clips Quote Link to comment Share on other sites More sharing options...
omar302 Posted June 2, 2021 Report Share Posted June 2, 2021 Are you sure your 2015 Edge Sport has HID? from the looks of it, it seems you have regular halogen bulbs which are standard on the Edge Sport (H11 bulbs). Link to the owners manual bulb specification chart. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted June 2, 2021 Report Share Posted June 2, 2021 (edited) yeah those are halogen fittings. HID was optional tho on the Sport, as part of the Equipment Group 401A – Technology Package https://drive.google.com/file/d/1_3Rmp0PrPfGFN898FZZuGBiob8UuZvOr/view?usp=sharing This is a typical D3S connection https://www.hidconcept.com/products/mitsubishi-d3s-d3r-connector-pack-of-2 Edited June 2, 2021 by WWWPerfA_ZN0W 1 Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted June 2, 2021 Report Share Posted June 2, 2021 (edited) In addition to what Omar and WWWPerf mentioned above. Assuming that you are not the original owner. If you think/ believe that your edge was originally equipped with HID, I would suggest going to a dealership and having them run the VIN and ask them to print you a build sheet. That would be the final word on whether or not you have factory HIDs. Your build sheet will be beneficial because it will tell you what options and features your particular model came equipped from the factory. Or you can go to the parts department (or call) and ask for a replacement HID bulb. Hopefully the counter clerk is serious about their job, and will ask for your VIN to double check...... Most owners want to upgrade from halogen to Hid. I can't imagine the original owner wanting to downgrade factory HID to halogens. Edited June 2, 2021 by onyxbfly 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted June 2, 2021 Report Share Posted June 2, 2021 if oem HID, the ballast should be mounted to the bottom (?) of the assembly. 1 Quote Link to comment Share on other sites More sharing options...
hyperc32 Posted June 21, 2021 Author Report Share Posted June 21, 2021 Hey thanks for all the replies , Had couple crazy past weeks so haven't been forum active... I ended up buying the DDM canbus kit works great got only the 35 watt kit much brighter and 4500k temp the FOV has damn near doubled Quote Link to comment Share on other sites More sharing options...
LipEdgeSport Posted July 19, 2021 Report Share Posted July 19, 2021 Can you link me to the ones you used? Interested in upgrading to HID. How are they holding up so far? Quote Link to comment Share on other sites More sharing options...
MetalAnon Posted November 26, 2021 Report Share Posted November 26, 2021 On 6/2/2021 at 5:31 AM, onyxbfly said: In addition to what Omar and WWWPerf mentioned above. Assuming that you are not the original owner. If you think/ believe that your edge was originally equipped with HID, I would suggest going to a dealership and having them run the VIN and ask them to print you a build sheet. That would be the final word on whether or not you have factory HIDs. Your build sheet will be beneficial because it will tell you what options and features your particular model came equipped from the factory. Or you can go to the parts department (or call) and ask for a replacement HID bulb. Also, in addition or perhaps in lieu of the above, if you'd rather not visit a dealership, @hyperc32, or anyone else for the matter, check my previous post... you should be able to get a hold of your original window sticker to determine what options your Edge was equipped with from the factory. HTH! 1 Quote Link to comment Share on other sites More sharing options...
