replacement gauge faceplates?
My used (but new to me) '07 Edge was originally intended for the American market but was recently brought into Canada probably as part of a fleet sale. The large numbers on the speedometer are MPH rather than KM/H.
I'm used to driving at 100 km/h, not 60 MPH. This may seem trivial but does anyone know if it is difficult to change the faceplates?
Unless it's rather simple and inexpensive, they'll stay as they are.
Thanks
Thanks
You would have to change the whole instrument cluster.
try to find a used cluster....unscrew the cluster and remove (carefully) the plastic gauge-plate. Then replace in your original cluster. I did this because I didnt like the black faces and found a used sel cluster. With a little care and common sense (patience), it was actually a fairly simple switch.
Edited by wthrower
I was wondering if you still have the black gauge plate. Ed
