2019 Edge ST ptu fluid service
kruzr1
  • 2 years later...
On 6/17/2023 at 1:41 PM, ST Road Runner said:
My 2019 Edge ST has two rubber caps as highlighted by the 2 red arrows.  Are these where a cooling unit would connect?  Irritating that 2018s have a drain plug and for 2019 they dropped it.
 Is this a US spec edge? My 2019 has the additional cooling for the PTU. All marketing material listed it as a liquid cooled PTU for the ST in my region (Newengland)
Edited by 1004ron
Yes, that is a PTU cooler with the ports plugged. My 2020 ST has a simple plug that was installed rather than the capped cooler. It appears that your Edge was built at some time during the transition from cooled to non cooled PTU's in Edge ST's
This is what the cooler looks like: https://www.rockauto.com/en/moreinfo.php?pk=11176489&cc=3444713&pt=2088&jsn=565
Read this link for my experiences, Ford diagrams and part numbers:
https://www.fordedgeforum.com/topic/31746-2020-edge-st-ptu-fluid-drain-fill/
Edited by CTEdgeST
  • Like 3
  • Thanks 1
Fingernip - Yes the picture is from a U.S. Edge.
CTEdgeSt - Perfect.  Thank you for the picture of the cooler at Rockauto and the other post detailing your drain and fill!
Looks like I just need to purchase the purchase the cooler plug kit (K2GZ-7A010-M), remove the cooler, let her drain and then replace with the cooler plug kit.
Super write-up and pics on your post.  Thanks for sharing!
Quote
Is the PTU fill plug a TP-50 torx bit
No, it is HW8 metric hex.
I don't know how long the cooler assembly is so I would be slightly concerned that it might run into the cross brace located directly behind it before it clears the PTU housing.
You can probably make a good estimation by measuring the length of the bulge for the cooler on the housing and comparing that to the distance from the face of the cooler boss on the PTU to the brace.
When I was working with an independent shop on this - their tech had worked on these at the dealership and had said that removing the cooler would involve taking the cross member out - but that may have involved other obstructions like the lines that are supposed to be attached to your Edge, but are not.  From what I saw on the cooler I looked at - it appears to run most of the length of that shape on the case.  It is infuriating that these things don't have drain plugs - what a screw up.
The other problem with these PTUs is straight up the volume of fluid - there just isn't enough of it.
ST Road Runner,  I guess you have at least 4 options:
1) The cooler comes out with no issue.  Even if  you can't remove it by pulling it straight back, you might be able to turn it so that the tubes move into the open space to the left and above the cooler mounting bore. If so, the cooler may clear the cross brace.
2) Even if the cooler can't be removed due to interference with the cross brace, it will still come out far enough to allow you to drain the fluid and then put the cooler back in place.
3) Move the cross brace to allow removal of the cooler
4) Replace the cooler with the plug like mine after forcing the cooler out without moving the brace.
Good luck, let us know how it went once you have completed the drain and refill.
Edited by CTEdgeST
Thanks CTEdge!
Going to get with a friend that has a lift and determine the best course of action to remove the cooler.  My preference will be to replace with the cooler plug cover, since it has a magnet to help catch the metal shavings and should make future drain much easier.  Hope to get this figured out over the next couple weeks and will report back.
  • 4 weeks later...
Ended up working with a friend at my local NAPA service center.  Unfortunately the cooler could not be removed due to interference with the cross brace, but they were able to get it out far enough to drain the fluid and then refill at the fill plug.  I have 56K mostly gentle miles on my ST.  The oil was captured in a container for inspection and they noted it came out looking pretty good with a small amount of metal filings.  Total charge $152.  Thanks to all for your input!
  • 9 months later...
Very interesting thread here. I just got my 2022 ST and am very interested in PTU related issues. So far i know PTUs on 2019+ Edges are way different to the one in previous years. I hope i will be able to look under my car in some days and provide with real photos. For the moment this what i found regarding PTUs for confused owners, like me.
PTU description:
The Power Transfer Unit (PTU) is a gearbox that attaches to the transmission. The PTU directs power
from the transmission differential case through a dog clutch to a hypoid ring gear. A hypoid pinion gear
is meshed to the ring gear and splined to the output flange. A dog clutch is used to transfer drive torque
from the input shaft to the ring gear. When the dog clutch is released, no torque is transferred through
the ring gear and pinion to the rear driveshaft. When the dog clutch is engaged, normal AWD function is
achieved by directing torque to the rear wheels as needed to prevent or control wheel slip and improve
handling
There are two different models of the PTU. The low torque PTU is paired with the 8F35, 8F40, and
MMT6 transmissions. The high torque PTU is paired with the 8F57 transmission. The low torque and
high torque PTUs are similar in design and operation.
And some drawings:
Item & description:
1 - Vent tube. Unique routing for each powertrain.
2 - PTU to transmission bolt for 8F35/40 & MMT6. One-time use.
2 - PTU to transmission bolt for 8F57. One-time use.
3 - Heat shield bolt
4 - Heat shield
5 - PTU to engine bracket bolts. Unique parts for each powertrain.
6 - 7B664 PTU to engine bracket. Unique parts for each powertrain.
7 - Oil temperature sensor harness bracket (If equipped).
8 - Oil temperature sensor harness bracket bolt
PTU cooling system - if equipped:
Item & description
1 - Fan and bracket assembly
2 - Fan and bracket assembly bolt
Item & description
1 - Oil-to-Coolant cooler stud. One-time use, part of 7P159 kit.
2 - Oil-to-Coolant cooler. Part of 7P159 kit.
And operating modes description:
Power Transfer Unit (PTU) Operation
The PTU has four (4) distinct modes of operation: Connected, Connecting, Disconnected, and
Disconnecting. Each mode is commanded by the AWD module. The PTU contains a reversible DC
motor and two hall effect position sensors. The motor moves the shift fork which connects or
disconnects the dog clutch collar. PTU Position sensor A monitors the position of the actuator cam. PTU
Position sensor B monitors the position of the shift fork. Some PTU models are equipped with an oil
temperature sensor
Connected Mode
Connected Mode is the default mode for the PTU. The AWD module will command Connected mode at
the beginning of each key cycle. In connected mode, the fork and dog clutch collar are positioned
towards the RH side of the PTU. The dog clutch is engaged. The driveshaft is rotating at an overdrive
ratio compared to the front axle shafts. Torque is available at the RDU.
Connecting Mode
To connect the PTU, the two halves of the Dog clutch must be within 40 RPM of each other. The AWD
module calculates the speed differential based on transmission OSS, RDU Driveshaft Speed, and PTU
gear ratio. The actuator motor will energize and rotate the gear reduction drive and the actuator cam
against the actuator fork. When the dog clutch teeth line up, the cam pushes the actuator fork into
position and the clutch engages. It can take approximately 100 - 150ms for the dog clutch to engage after
the command is sent.
Disconnected Mode
The AWD module will command disconnected mode based on vehicle conditions. The purpose of the
disconnected mode is to reduce drag losses from spinning the driveshaft when conditions indicate AWD
will probably not be needed in the near future. In disconnected mode, the fork and dog clutch collar are
positioned towards the LH or transmission side of the PTU. The dog clutch is disengaged.
Disconnecting Mode
To disengage the PTU, no torque can be routed through the dog clutch. That is, the RDU must be
completely disengaged. Depending on vehicle conditions, the AWD module may keep the PTU engaged
for the remainder of the key cycle. The actuator motor will energize and rotate the gear reduction drive
and pull the actuator cam away from the actuator fork. When the dog clutch collar has moved far enough
to the LH or transmission side, the dog clutch teeth disengage.
Wondering if i have one on mine.
Have fun guys!
  • 4 months later...
  • 2 months later...
Replicator. Those 2 plugs are where the COOLANT hoses would hook up to circulate coolant through the cooler. So, no you cannot drain the ptu fluid by removing the caps. Looks like that was during the transition stage to the liquid cooled ptu system. From 2019 on they also added a cooler and an electric motor that would circulate coolant through the ptu to help with heat. I verified this on my 2021 ST. I just traded in for a 2024 and the PTU system identical.
I also found that when you shut the car off, this electric motor continues to run for a few minutes, circulating coolant through the ptu, to help with heat soak.
The newer style also have a temperature sensor install where the fill would be.
All I can say is if they are using HOT coolant to help with the ptu failures, these things must be getting hot!
Edited by 1004ron
