Backseat cigaret lighter replacement
Hi All,
I would like to install permanent USB jack instead of the 12v Cigaret Lighter in the back seat of ford edge 2017.
something like https://www.aliexpress.com/item/4000603995303.html
Any idea how do i remove the middle console in order to install it ?
I think that all that does is provide 12 volt power. I believe what the OP wants is a true USB connection (so he can connect to Sync). Can't do it with a power adapter. (Most cell phones come with a 12 volt power cord that does the same thing as this adapter).
To do what he needs, he must add an USB cable to the location (the Edge/MKX actually has 4 USB ports, but only 2 are wired) and add an USB connection point.
Several years ago someone in the forum showed how he added a connector to add 2 more USB ports. Couldn't find it using search, but as I remember it, it was a simple connection using a new USB cable and connection point.
Edit.
Found this. May or may not fit the bill for your needs, but a starting point.
Edited by enigma-2
