ymerameha Posted April 25, 2021 Report Share Posted April 25, 2021 Hi everybody Yesterday I went for a longer drive. DPF could have cleaned himself nicely, but instead began to make mistakes. At first, it showed a message that I didn't pay much attention to. Something "... drive to clean" and the only option was "OK". I pressed. After a while, the first icon appeared - "Service Engine Soon". After nearly another 100km, the "Powertrain Fault" icon appeared and the car was put into limited power mode. Tere are two errors in DTC that come back immediately after deleting with forscan: Code: P2463 - Particulate Filter Restriction - Soot Accumulation (Bank 1) Code: P246C - Particulate Filter Restriction - Forced Limited Power (Bank 1) What can I do with these? Only service? Thank you for your time Quote Link to comment Share on other sites More sharing options...
