HEC Posted April 21, 2021 Report Share Posted April 21, 2021 Like the subject says my question is.... Why is my defrost vents blowing out cold air when my a/c is on and no air coming out from the other vents (front vents) like it usually should did? In some blogs, they say I need to replace a door actuator that is located under the gloves box, and in others, they say that is another door actuator located behind the dash in the driver panel. Anyone can help me? Thank you Quote Link to comment Share on other sites More sharing options...
ben senise Posted April 22, 2021 Report Share Posted April 22, 2021 8 hours ago, HEC said: Like the subject says my question is.... Why is my defrost vents blowing out cold air when my a/c is on and no air coming out from the other vents (front vents) like it usually should did? In some blogs, they say I need to replace a door actuator that is located under the gloves box, and in others, they say that is another door actuator located behind the dash in the driver panel. Anyone can help me? Thank you just to be sure but does this happen after the engine has warmed up? have you tried the "Max" button and does the same thing happen? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 22, 2021 Report Share Posted April 22, 2021 18 hours ago, HEC said: Like the subject says my question is.... Why is my defrost vents blowing out cold air when my a/c is on and no air coming out from the other vents (front vents) like it usually should did? In some blogs, they say I need to replace a door actuator that is located under the gloves box, and in others, they say that is another door actuator located behind the dash in the driver panel. Anyone can help me? Thank you can you tell us some basic info: year, model, trim level, manual or automatic climate control? this sounds like a mode door issue if air is not coming out from where it is supposed to. temperature control is via blend door actuators. Quote Link to comment Share on other sites More sharing options...
