Btaylor Posted April 20, 2021 Report Share Posted April 20, 2021 I just bought a 2016 edge platinum and I can’t get the navigation to work right. I joined the forum and read through all the navigation threads I could find. The navigation is very far off and doesn’t register direction changes until sometimes 10 minutes later. I have done the reset, then the factory default reset, pulled the fuses for half hour, did the resets again. Then in the diagnostics screen I was able to see that there was plenty of satellites in range, however two of the 7 were a little week. I replaced the antenna and did the resets again, the signal showed stronger now but the original problem remained. I checked my sync version which showed to be updated in November, checked the latest version is the same but reloaded it anyway. I constantly have the red x in the gps symbol. Weird part is it actually works for brief periods of about 2 miles or so. Any ideas would be appreciated, I don’t feel like spending hundreds of dollars to have the dealer diagnostics and more to repair it. Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted April 20, 2021 Report Share Posted April 20, 2021 Update SYNC. SYNC gets goofy every now and then. There are a few members myself included that had the issue. Unfortunately I'm at work and hopefully someone will chime in with a solution for you. Quote Link to comment Share on other sites More sharing options...
circatee Posted April 20, 2021 Report Share Posted April 20, 2021 Rather odd. To confirm, during your testing, the car is in the driveway, thus antenna has clear sky access? Quote Link to comment Share on other sites More sharing options...
ben senise Posted April 20, 2021 Report Share Posted April 20, 2021 are you using the car's built-in navigation or a phone that is attached with a cable (i.e. android auto or car play)? i've had some bizarre situations with the phone connected using google maps. the car icon on the sync screen would jump all over town and recalculate continuously. it appears to only happen when i pull out of an underground parking where the car has been overnight. it's inconsistent though. from what i've read and my understanding of it, android auto or apple car play on sync use the gps antenna on the car as well as the phone. what i would need to do next time is disconnect my phone from the edge to see if the map on the phone screen is correct. Quote Link to comment Share on other sites More sharing options...
Btaylor Posted April 20, 2021 Author Report Share Posted April 20, 2021 Yes the vehicle is parked outside when I am testing and resetting. This is with the vehicles gps it happened before I connected my phone (unfortunately should have tried it on the test drive), as well as after. After the factory reset it unpairs the phone completely and I tried doing the troubleshooting for a few days without the phone paired because I read about the possible interference. I definitely appreciate your thoughts though because every thought helps. Quote Link to comment Share on other sites More sharing options...
Btaylor Posted April 20, 2021 Author Report Share Posted April 20, 2021 Also forgot to mention I did update sync just two weeks ago directly from a thumb drive just in case the WIFI download was corrupted. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 1, 2021 Report Share Posted May 1, 2021 (edited) Are you able to pull codes? I remember that there were a lot of similar complaints about the 2016 system. If I remember correctly, the fix was to replace the APIM. Edited May 1, 2021 by enigma-2 Quote Link to comment Share on other sites More sharing options...
Btaylor Posted May 1, 2021 Author Report Share Posted May 1, 2021 I haven’t yet, been too busy but plan to tomorrow. I was hoping it isn’t the APIM due to the cost but that was my thought as well. Since the unit isn’t showing fault codes I hope my scanner can, it’s a professional model that does coding as well. Have you heard what codes were the signs of a faulty APIM? Quote Link to comment Share on other sites More sharing options...
Btaylor Posted May 1, 2021 Author Report Share Posted May 1, 2021 So I pulled codes and it shows gps antenna open circuit, I replaced it already but when I have time I will put the factory one back in and recheck it. If it shows the same I guess it’s the APIM. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 3, 2021 Report Share Posted May 3, 2021 Before you consider a new APIM ($$$) check the GPS antenna connection on the back of the ACU (radio). Also check for corrosion on this connection. When the ACU loses the GPS signal, it maintains the navigation by "guessing" based on speed and time. When the GPS syncs up again, it updates the screen and the map "snaps" to your current location. I wonder if the real failure is the GPS module itself. I don't know where the module is on your car, on my 2009 MJX it's above the radio, under the speaker. My guess would be the GPS antenna or module. Quote Link to comment Share on other sites More sharing options...
Btaylor Posted May 3, 2021 Author Report Share Posted May 3, 2021 Awesome, thank you, I will check that out. Just got to rip the center dash section apart again to do it, so it might be a couple days before I get to it. 1 1 Quote Link to comment Share on other sites More sharing options...
ChadD74 Posted January 14, 2023 Report Share Posted January 14, 2023 Did you resolve this issue?? I'm having similar issues Quote Link to comment Share on other sites More sharing options...
Btaylor Posted January 14, 2023 Author Report Share Posted January 14, 2023 No I was going to pull the unit apart and check the solder to the board. Ended up trading it in Quote Link to comment Share on other sites More sharing options...
