Quiet turn indicator relay - 2020 Edge ST
The noisy turn indicator relay is pretty annoying. Anyone find a solution to quiet it down, like an electronic one verses the noisy relay?
On edit: I seems that this may be digitally created clicking from a little speaker in the dash somewhere!!! Still need a solution, it may also create the door chime tones. Thanks Chris
Edited by Snoking
There's a tiny speaker attached to the instrument cluster (on the left side of the steering column if I remember correctly).
You can remove the instrument cluster and the either tape over the little hole, wrap foam (or whatever) around it to muffel it, or remove it completely.
The sound is sent to it from the SJB (fuse panel) as it creates the flashing signal for the various signal lamps.
