Edgeyowner2014 Posted March 30, 2021 Report Share Posted March 30, 2021 I put a performance chip on my 2014 Ford edge, to where now it will exceed the factory speed limiter. I put on a wider set a tires that are Z rated, and now at higher speeds of 90+ I get a lot of body sway. I put new swaybar in links on all the way around, all the front components are tight, I was wondering if anyone else has experienced this issue and if so,Has anybody put on a steering stabilizer? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 31, 2021 Report Share Posted March 31, 2021 I remember reading that new tires will sway at high speeds, until they break in. In a towing situation, others reported lowering tire pressure helped in a sway situation at high speeds. Could try dropping 5 psi and see if it improves. 1 Quote Link to comment Share on other sites More sharing options...
thecolin85 Posted August 11, 2021 Report Share Posted August 11, 2021 I'd also be curious if there were ever any worthwhile suspension products made for a 2.0 Edge. Stiffer sway bars and endlinks would go a long way in aiding these issues. Alas, no one makes anything for these vehicles do they? I mean I saw some slightly-nicer-than-OEM shocks from Bilstein. and then some H&R lowering springs. but that's about it?? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 12, 2021 Report Share Posted August 12, 2021 look up dealer catalogs to see what part goes across different powertrains/drive configurations. you might get lucky. addco has been a popular custom mfr of swaybars on this platform. you could call them up. 1 Quote Link to comment Share on other sites More sharing options...
thecolin85 Posted August 12, 2021 Report Share Posted August 12, 2021 On 8/12/2021 at 12:22 PM, WWWPerfA_ZN0W said: look up dealer catalogs to see what part goes across different powertrains/drive configurations. you might get lucky. addco has been a popular custom mfr of swaybars on this platform. you could call them up. Expand Thanks for the reply! Can you please elaborate on your suggestion? I just want to make sure I understand. Are you saying look up OEM parts catalog for say, my 2019 Edge 2.0 and find the part numbers for the sway bars & end-links (OE) and that will somehow allow me to find aftermarket suspension products that fit? Like, are you saying grab the part number for the sway bar, let's say, then just search that sway bar only and see what other vehicles it has been used on, and then go look up manufacturers like ADDCO etc and search by that cross referenced make/model/year vehicle and see if they offer any products that will fit? Like, let's say I search the sway bar part number and find that it also was used/fits on like a 2018 Ford Fusion or Escape (idk), and then I search ADDCO's site for a sway bar for a 2018 Ford Fusion and it brings something up, then I could pull the trigger purchasing that product knowing there's a 90%+ chance it will fit our application? Thanks! PS: ADDCO is good, used their larger thicker sway bars when I supercharged my 5.9l Jeep GC years ago. Also lowered it with H&R springs for better handling w/ Bilstein shocks. Both of which seem to be the only suspension option(s) for our Ford Edges ATM. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 12, 2021 Report Share Posted August 12, 2021 (edited) you can look up parts that fit your specific configuration, and then check to see if they fit any other configuration. like does an ST part fit the 2.0 also. if so, you have cross-fitment and can look to see if there are aftermarket parts that fit the ST. the aftermarket is still poor, but on this forum, many custom items have been developed for the 2015-2018 sport. if the ST item also fits the 2015-2018 sport along with the 2.0, that will make your quest much easier. the dealer catalogs will show you crossfitments. always anticipate some minor fitment issues tho, not insurmountable, but the way it goes with custom stuff. https://parts.levittownfordparts.com/ P.S.: be SURE the part fits the Edge/MKX/Nautilus ... do not assume a Fusion/MKZ part will fit this platform. Edited August 12, 2021 by WWWPerfA_ZN0W 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 15, 2021 Report Share Posted August 15, 2021 Rereading the posts, you mentioned you put on tires not recommended (wider than specified). I wonder if the Roll Stability Control which is incorporated in the AdvanceTrac may sense an inbalance (due to the new tires) and is trying to compensate. Did you notice the roll with the old tires? 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 16, 2021 Report Share Posted August 16, 2021 speaking of wider tires, you could have tramlining issues if the roads have "deficits". https://www.tireamerica.com/resource/what-is-tramlining 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted August 23, 2021 Report Share Posted August 23, 2021 (edited) On 3/30/2021 at 10:05 PM, Edgeyowner2014 said: at higher speeds of 90+ I get a lot of body sway Expand Perhaps you are taking your town's slogan too literally. Good luck! Edited August 23, 2021 by Haz 1 Quote Link to comment Share on other sites More sharing options...
itsnotdustin Posted August 23, 2021 Report Share Posted August 23, 2021 On 8/16/2021 at 7:21 AM, WWWPerfA_ZN0W said: speaking of wider tires, you could have tramlining issues if the roads have "deficits". https://www.tireamerica.com/resource/what-is-tramlining Expand This ^ Wider wheels/tires have this affect with all vehicles. The wider the tire, the worse it gets. 1 Quote Link to comment Share on other sites More sharing options...
